hey all...
Have a few things i want to get rid of:
Will pay postage!!
- ARIAS PISTONS + RING KIT (BRAND NEW)
Suit rb26, Suit bore size of 86.5mm. Pistons are 20thou over. These are brand new and i can provide detailed spec's on the pistons if Someone wants them.
PAID : $1550
PRICE : $1350
- STANDARD GTR PISTONS
Excellent condition No Damage
PRICE : $ 200
ALSO
Have Full GTR R32 interior
-Dash
-consols
-roof lining
-Front seats SOLD
-Rear Seat
-Carpet
-all Side panels
-Foot panels (comp cover)
Plus more.....
Offers if interested in anything or we could work out something for the whole package......
cheers
https://www.sau.com.au/forums/topic/79997-gtr-parts/
  • 3 weeks later...
how are the condition of rear seat and carpet? any pics?
please send to [email protected]
Hi Intrested in full carpet,
have you still got or sold?
thanks very much
https://www.sau.com.au/forums/topic/79997-gtr-parts/#findComment-1496609
Hi
I have sent u 2x pms - not sure if the forum is playing up or not.
defo intrested in some stuff for this week.
please get back to me with a ph number and we can sort somehting out.
after the carpets and maybe some other interior bits and bats...
[email protected]
thanks
mick
https://www.sau.com.au/forums/topic/79997-gtr-parts/#findComment-1498246
yeah same with me,
i am interested in the piston set, if the PM function isnt working can you please email at: druzilla32 @ hotmail . com
i would like to know more about it,
"Suit bore size of 86.5mm" << im assuming these wont fit directly into the engine? what has to be done?
https://www.sau.com.au/forums/topic/79997-gtr-parts/#findComment-1498284
Hi,
Please can you email me?
I know yo have tried PM, but something going on with pm replies and stuff with this stupid upgrade.
Are you In Sydney? or Melb?
Really wan to get some stuff off you asap.
Please email you Ph number.
[email protected]
Thankyou
https://www.sau.com.au/forums/topic/79997-gtr-parts/#findComment-1499113
I have written you an email as requested
Cheers
Hi,
[email protected]
Thankyou
https://www.sau.com.au/forums/topic/79997-gtr-parts/#findComment-1500024
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
