If My Rb26 died in my R32..... instead of paying heaps for a rebuild or putting a new rb26dett in there...could it be possible just to limp around in an rb20 (cause they're so cheap) just untill possible new rb26 is available
so yeh possible 2 fit rb20 into gtr or not worth it?
They are probably only slightly more expensive because of the differential in the sump. You could get one without a sump and transfer the GT-R's sump onto it (you will have to swap out the diffs anyway - different ratios). The other problem is that the looms are slightly different (2 AFMs, 2 O2 sensors, etc), so you might need a new ECU and possibly new loom.
The only RB25 is from the Stagea, and they aren't cheap ($3500 - $4000)
