HELP! I need some mesh...
Mostly likely welded. 'Coz it's f**ked. You have the car right there. Get someone to tap on the underside while you sit in the back with the seat out. You'll find it faster than we will.
By DatsunBanana 路 Posted
Yeah, I'm pretty sure that's how it's going to end up. Mechanic suggested I cut a hole in the chassis/body to access the inside. I can cut the hole for access but will have to get someone else to help if any welding is needed afterwards. Things I'd like to know are: Assuming there's a captive nut inside, how's it fixed? And how can it be tightening but not fully loosening? If I cut a hole to access/replace a captive nut, is there a good place to cut for this one? Does it have to be at the side, or is there somewhere I can cut from above inside the car? -
By PotatoCake 路 Posted
So i finally got the exhaust done. Full custom 3.5" stainless with dual tipped sp mufflers & a side exit aes dump valve. Not as quiet on the outside as i thought it would be, but heaps quiter inside when driving and no more drone. Some pics on Instagram -
The wasteland, as least traditionally too, was the place with more relaxxed shittery/rules. Not to say you can post porn etc, but it was the place for good joking around, and a bit wild. There was also plenty of unwritten wasteland rules, such as what any user must do if someone posted up asking for likes/votes for a contest... Which was to go in and vote for someone else instead 馃槢
