Group Buy - Genuine Hdi Intercooler Piping Kits - From $437
  • 3 weeks later...
Hey I noticed on the site you've got an intercooler on a GTiR on your site. Did you use this piping kit to fit it to that GTiR? Is moving the washer bottle and removing tow hook cover necessary for these kits? Any how-to-guides I can have a look at?
Thanks,
Andy
Thanks,
Andy
Piping kit on the gti-r was actually a hybrid copy from one of the group buys on here from one of the other guys (I couldnt be bothered getting in 50 piping kits just to fit my one.... lol)
The washer bottle was moved over a bit and radiator overflow was also moved, tow hook was removed.
I don't have any how to guides at the moment, although the genuine HDi kits that we have coming in come with full instructions. I only have 2 piping kits for gti-r's coming in as there wasn't much interest in these. So 2 piping kits left for gti-r.
Cheers,
Greg
So the HDi ones you have are like the Hybrid ones? Will they suit a 450x300x75 intercooler? I don't want to use a 600x300x75 because I believe most of it is surface area isn't being used efficiently and its just a waste.
Hi mate, have a search on the net and you'll see what HDi is.
We do not sell Hybrid..
Unfortunately the piping will be slightly off if used on a car with 450mm cooler as the kit is designed for 600mm cooler.
The 600's aren't bad especially when you can also get our new GT Spec kit (tube and fin)
At the end of the day its personal opinion.
Ship is confirmed to land on the 7th of August.. Get in quick :D
Cheers,
Greg
thanks , Greg ,
package arrived safe and intacked ,All peices were there . looking forward to installing the intercooler,Now the fun starts , Also tahnks to Australia Post .Bunbury WA
Edited by beetle
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
