i did post this in the forced performance section but got no replys
I have just spoken with nissan regarding a new oil pump to suit my series 1 rb25det. The two options that they gave me were for either a "standard pump" or an "rb26 pump"
part no's and prices
150105L800 - $488
1501024U01 - $536
I am guessing that rb26 option is what we know as the n1 pump. Can anyone confirm this via the part numbers?
Also I didn't think that the standard pump was going to be so close in price to the N1. From some of SK's posts he was talking about a difference of a few hundred $$$, anyone know where to get the standard pump cheaper?
leigh.
https://www.sau.com.au/forums/topic/80084-rb25-oil-pumps/
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
