  sky_m6m9 said:
both has manual and auto mode, look around for some description
The new GReddy Full Auto Timers pack tons of features in one economical, compact unit. In addition to two standard programmable count down presents (P-1, P-2) our timer also has two Auto Timer modes,(A-L, A-H) which estimates the driving RPM according to the vehicles alternator signal and then recommends a count down time. And now there is a Stopwatch/Lap Time mode, and Attack mode. There is also a built in Voltmeter and Speedometer. Still standard are the optional Parking Brake and Speedo Safety hook-ups.
HKS timer type 0
The HKS Turbo Timer Type-0 is a basic turbo timer that features an auto mode that adjusts engine idle time according to the most recent driving pattern, multiple preset times, audible alarms and a volt meter. The easy to read back-lit digital LCD display flashes between orange and red during the countdown.
Price: $186.20
  her32 said:
Greddy I say...
I have that greddy timer, its prutty :P
Its got loads of features, you can read battery voltage, rpm, speed, lap times and quater mile times, the list goes on...im satisfied.
kewl that was my first choicie ... so it is does workout the time needed and then does it ?? or does it just recomend a time ?
Oh to answer the question gtst-25...
It does both. You can pre-set your time using P1-P2, or hook into rpm signal and use Auto mode. Make your selection and every time ignition is turned off it will remember either your p1-p2 set time, or suggest a time relating to how much thrashing it copped.
There's a booklet online somewhere in english for this timer, i printed out the 20 or so pages but dont have it with me :P
type 1 does a lot more. I normally leave it on the Rev Display, which has a 2 stage shift light feature. also has top speed, and all the standard performance measures (1/4 mile, 0-100 etc). Check out the English manual. you should be able to find on @ HKS-USA
:P
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
