So Everyone Knows SAU Vic Made It Into The Latest Speed Magazine Right?
  • Replies 58
did they say why this was the last?
They got tired of making soooo much money; they decided to give rival mags a chance in the marketplace :P
Or
I heard that a dragon ate 80% of Speed staff including there publishing editor. Footage of one person’s demise was recorded: :wizard:
:P
Had a brief look through this when I got home last night. Looks great Joel - and I'm really glad to see a great mix of cars in the shots. The one of the lines through the twisties looks awesome.
Thanks again mate - we owe you a beer on Tuesday night!
Anytime Andrew,it was good fun day too
Beer is always a good reward !!!
Someone should tell robin his car's in the mag.
Nice cross representation of cars, they even managed to drag a clapped out R31 out from somewhere and plonk a bum in front of it.
Hey my car made it into 4 of the photos!(p16, 72, 73 and 74) (albeit very small in 2 of them) And you can see me standing at the pier behind the cars wearing my black t-shirt. It was a great move driving 3 car ahead of the camera car all the way down the GOR.
Maybe this is my 15 seconds of fame...
I think Robin's car also made it to page 145 aswell.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
