I wanna rebuild my blown engine. Like everyone, I want something good but keep it low cost as possible.
I was thinking of getting a T78 33D Turbo (around 350kw).
Besides the forged pistons, what other stuff are a 'Necessity' to handle such power.
Those with knowledge in this department, please give me a list of what I am looking at, and how much each part will cost.
Just trying to get an overall view of what i need and $$$ it will cost. If its gonna go above my desired budget, i might have to settle for a hi-flowed turbo, and nothing too serious in the engine.
Thanks a lot.
Husnu (Hus).
  • Replies 64
I know someone who has the whole T78 33D Kit (External Wastegate, Exhaust Manifold, Dump Pipe + a few other piping with it). It will cost me around 3K mark, which is a bargain.
Putting those costs aside - i wouldnt want to spend more than 5K on the engine. (Am I living in La La Land?)
Do not use a T78 to make 350kw. This turbo is way too laggy and you'll have a horrible power band for only 350kw.
Rough estimate using all new Tomei stuff:
Prices USD$
Pistons 1,400
Rods 1,300
260° Cams w/pullies 850
555cc Injectors 780
1.2mm Headgasket 280
Apexi Power FC 1,200
Then you still have to add labor.
What mods does your car currently have?
are you taking the motor out yourself Hus?
if you do and can simply send it off to get machined then you should be able to get it rebuilt for less than 5K...
pistons ($1200)
rods (GTR Rods? $400)
bearings (??? maybe $200?)
water pump ($120?)
timing belt ($60?)
head gasket ($200)
head studs ($40???)
welsh plugs (???)
machining (depending on what you want/need basic tidy up probably cost $2000)
and of course anything else I have forgotten as I am not a mechanic
and a clutch to hold 350kw
Car currently has HKS FMIC, Rajab Racing Custom Clutch, HKS Hypermax Coilovers, 3" Kakimoto Turbo Back Exhaust, Hi-Flowed Turbo, Arnage LSD Diff.
Ok, put aside 350kw - say the T78 will hit 450-500kw - would i still need the same parts as what i was going for a 350kw - or extra parts?
So for 6K (excluding turbo kit) - i wont be able to do much?
still need cams ecu etc i think plus work and gaskets....i dont think 6k is enough..
ok.., throw away the idea of T78
I want to build an engine to suit 300kw at the wheels.
Put aside the turbo kit (I may go for a T67 25G).
Can i get a descent built engine for 6k? Or should i just buy a 2nd hand engine and drive with a 160kw skyline :)
If you wanna make 300kw go with a TD06 L2 20G or a GT3037. You might be able to make this on stock internals. You'll still need an ecu, injectors, fuel pump, and a boost controller. Cams would be a good idea too. I think the stock headgasket is fairly strong on an rb25.
Remember 6k will get you a half cut... So you could sell off the trans and other bits then use the brakes and sell the intercooler... By the time you buy and sell stuff you will have like 2g's left over to spend on cams, pfc & fuel pump..... Thats what id do with 6 g's...
And of course youll get a few bucks for the blown motor
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
