$150 to person who fixes my leak between manifold and turbo
I have a R33 gts-t s2 skyline.
I had a look at the engine a few min ago and found ive got an exhaust leak at the flange between the engine manifold and the turbo.
I previously thought i wasn't getting full boost which was wrong. There is a distinct smell of exhaust fumes entering the car so I wont be going on long trips.
Joviant on the Northern Beaches will charge me for 6 hours labour at $80 per hour and about $100 for parts. Another local exhaust place wouldn't touch my car because its a turbo.
Can someone recommend a place to take it to because I can't afford $500.
I'd be happy getting one of the forum members to work on my car because i'm not confident in doing it myself. I'll purchase the parts needed.
$150 to someone that is willing to fix my skyline located in Sydney (northern beaches).
I'll throw in a carton if wanted but I havent drunk since my 21st so it will be a lonely drink.
Let me know if anyone is interested.
Mark
first thing I would do is check that the bolts are all tight, though they should be 'cos they'r supposed to be locked. Then I would be looking at just replacing the gasket and seeing if that worked, it probably will, about 2 hours all up I would think + cost of a manifold to turbo gasket.
if its the exhaust gasket between the turbo & manifold i replaced it on my gf's s14 a couple of weeks ago! was $45 for the gasket plus took me like ALL day but i'm a slow worker plus no need to rush it my gf's paying me (hehehe) in favours! o and a mate helped me for about an hour which is when i got most of the work done! i didn't even pull the turbo all the way off, just down far enough to get the old bits of gasket off and the new one on! just make sure none off the old gasket drop into the exhaust housing when doing it! and use anti seize, i used molykote 1000 when putting all the nuts & bolts back on! i broke one of the heat sheild bolts trying to undo it!
Today I went to talk to Richard from PR Technology (near the post office) but they were all shut and didnt have any notice in the window indicating when they will reopen.
I also tried ringing the place I bought the car from but they don't seem to be around either.
Why do things go wrong when everyone is on holidays and its the first time you really need your car. grrr.
I blame Murphy - him and his laws.
Mark
There was a white van there when myself and a friend went down. The garage doors were closed, and feeling the front of the van the engine seemed cold indicating that it had not been run recently. We went there between 9:30am and about 10:30am.
Maybe he popped in later in the day :)
Seems like a place that specialise in Porches, does he do work on your skyline?
Mark
I've recently changed a turbo that I have never done before.
Then I had to put the origional back on again.
All up putting a turbo on and putting every thing back together took me 2hrs.
The first time it took a whole day to remove and re-install
Here's a quick run down on how to replace the gasket.
Remove the cross over intake pipe.
move the ic piping so that it doesn't get in the way.
this should take no more than 30mins now you can't see anything above the turbo.
Get a big flat head screw driver and bend the tabs straight that lock the nuts that attach to the manifold.
Grab a 1/2" sized ring spanner and remove all the nuts.
Use a hammer and tap it with another ring spanner forced up against the ring spanner on the nut when removing the lower bolts.
This wont have to be done if you have good quality ring spanners like i.e Sidchrome as they are relatively thin around the edges and will slide all the way on to the bolt not hitting the exhaust housing.
Chepo's will hit the edge of the exhaust housing and cause you to curse and possibly round off the nut.
Now simply pull the turbo out away from the manifold. There should be enough flex in the exhaust. You may have to loosen off the Bov return bolt that holds it firm which is next to the Intake crossover pipe to get enough flex without having to remove the afm.
Slide the new gasket ($37 from Nissan) in and do up the nuts, then slap all the rest back on and off you go.
If the leak is between the manifold and head you will need a new gasket about $100 as i only recently got one. You will also probably break a few studs when you go to take it off. Once you have got the manifold off i would recomment replacing all of the exhaust manifold studs as you wont wont to do this all again later, they only cost $2 each so there is another $24.
Would recomend taking the turbo off and replacing the gaskets for that as well. Don get these from nissan just go to any turbo place.
Will probably take you a day to do if you dont have lots of experience.
Clint,
When you say any turbo place, where do you mean..
I dropped in to Motor mates and they said its not listed for a VL 3ltr and to go Genuine or Motor Traders.
I Autobarn Sell the turbo to manifold gasket for $30 but they didn't have any at the time i needed one.
i had the same problem with mine but worse it was the manifold to head gasket
i would not recommend doing this unless you have the neccassary tools because if the bolt snaps inside the head as 4 of mine did you need to drill into the bolt and use a set of easy outs to extract it
easy to do if its cyl 3 or 4 but if the bolts fron 1,2,5 or 6 go your going to need a right angle drill cos its a tight fit ti get in there
beleive me i did this about 4 months ago
to check for where the leak is look for exhaust residue around the gaskets this will tell you where its comming from
or when engine is cold( so you dont burn your hand)
feel around for exhaust blowing out as you rev the engine a bit
good luck
if you want ill have a look at it for you and see if we can find the leak
5 hrs to put the thing back on when it took 2 hrs to take off?!?!
Putting it back on is easier and quicker.
One trick is to fit the wastegate once the turbo is bolted and also fit the oil drain pipe once the turbo is bolted on.
Then it slips in there no problems, I had trouble with the oil drain pipe causing a restriction to movement when trying to slide it on the dump pipe then the manifold.
Sorry to Hijack...
Where can I find replacement studs? What are the (stud) measurements i should be chasing (also on a RB20DET ) ?
Thanks,
46n2
