"The Sard Rising Rate Fuel Regulator is the best on the market. It holds the highest pressures and more importantly its the most stable with its linear progression. Constructed out of CNC Billet Aluminum and with an anodised finish for extra durability. Fits all Turbo and N/A EFI Cars. Increase your power and prevent detonation due to leaning out during high revving and boosting. Can add upto 30rwkw over the stock fuel system capacity by using a Quality Bosch Fuel pump and a Rising Rate Regulator. Suitable for all applications upto 500HP running 23 - 116 PSI Fuel Pressure. "
Bought brand new, and never used, (still in plastic)
$199
PM or call 0400261099
https://www.sau.com.au/forums/topic/80124-sard-fuel-pressure-reg-cheap/
I'll Give You 150
As per PM yesterday burko1, the price is $199 firm, I doubt you will ever find a Sard rising rate fuel reg brand new, still in plastic for $150, unless it was stolen.
The price is $199 pls do not ask again.
Rs,
As per PM yesterday burko1, the price is $200 firm, I doubt you will ever find a Sard rising rate fuel reg brand new, still in plastic for $150, unless it was stolen.
The price is $200 pls do not ask again.
Rs,
NO WORRIES I'D RATHED BUY ONE AND GET A RECEIPT THEN
THANKS ANYWAY
Hello there,
I cannot believe anyone hasn't bought this yet, they retail at over $249 at your local tuning shop.
These are great for massive fuel pressure, we use one of these on our car and its holding 65PSI of pressure without worries :)!
    • Yeah. OK. I'll say the same thing I say to everyone. You do not have to use 100% throttle all the time.
    • Mainly being afraid of breaking something on something i've poured so much money into haha
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
