anyone ever heard of one/know where to pick up one???
trying to remove crank pulley bolt,
i tried wedging a screw driver into the teeth of the fly wheel ringgear
whilst trying to undo the pulley bolt but that was kinda dodgy and didnt work....
anyone know any other ways of removing the bolt without the ringgear stopper?
i also tried just putting the car in gear but that also didn't work...
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/
Put an impact socket on a strong, long, breaker bar. wedge the end of the bar on a chassis rail or something really solid. Disconnect the coil loom or otherwise stop the engine being able to start. Flick the starter key for a fraction of a second. The starters power and the engines inertia wil jar the bolt free. be careful, if something slips or breks metal can go flying with serious force, don't have anyone standing overlooking the engine bay!. A bit crude, but very effective and a commonly used practice. Nicer way? Air gun on the pulley bolt.
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1458141
I undid mine not long ago, i bent a few ratchets in the process and a rattle gun wouldnt budge it.
I purchaced a strong/long socket bar from repco and a THICK long pole on the end of that and even then it took me a shit load of back and forth tugs before it snapped loose. I couldnt believe how tight it was!
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1458144
Driver: I undid mine not long ago, i bent a few ratchets in the process and a rattle gun wouldnt budge it.
Yeah but how did you lock up the ring gear on the flywheel to enable you to stop any rotation of the pulley??
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1458165
I managed to do it with the 2-screwdriver trick. The screwdrivers need to be reasonably substantial, and you need a long breaker bar on the bolt. This was with the engine out of the car, though. Also helps to have a helper.
I've also done it with the engine installed (to replace the water pump). Pretty sure I just stuck it in gear, and used a 18" breaker.
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1459043
Put it in gear and pull the handbrake up very hard , if you have a helper get them to put their foot on the brake .
If you have a gtr you will need a 3/4 drive 30 mm socket and a srong bar , for a gts 27 mm socket .
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1459061
Yeah i tried that but even with sumone pressing the brake the car was moving...My clutch is on the way out (slips during launches more than 3500) Could that be the problem? I guess it cant really be cuz the car still moves. The brakes just dont seem to bight enough without any booster.. Im thinking to just re install the starter and do wat Chris Wilson posted...Any more tips?
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1460262
Still no luck with the crank pulley bolt. ive tried putting a screwdriver in the ring gear teeth and it wont hold it enough. Just slips and sparks. So i tried putting th starter back in and using a breaker bar jammed up against teh chassis rail while i flicked the starter over for a second. That also didnt seem to have enough power to undo it. I tried that alot of times but was worried it would burn out the motor... I need HELP!!
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1462073
The starter will work if you have a fully charged battery and dont jam the bar on the rail , leave the bar some slack and put a block of wood on the rail so the bar hits the wood and not the rail . Hit the starter and if it doesn't undo don't hold the starter on , let go and try again but this time give it more slack , 2 or 3 goes and it will come . Make sure the bar will hit the wood only otherwise you will damage whatever it hits and don't stand in the way .
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1462753
Hi Deren, I replaced my 32 GTR timing belt a couple of months ago and had a god awful time getting the crank pulley bolt off. The "breaker bar on chassis rail and crank the starter" method does not work on RB26's as the bolt is torqued too tight - it works OK on 25's and 20's as their bolt has half the torque of the '26.
This is how I got mine undone:
1. Car in 4th gear, hand brake on as hard as possible, helper in drivers seat with foot as hard as possible on brake.
2. Breaker bar on crank bolt with long pipe (1.2metres) on breaker bar handle.
3. Put as much pressure as you can on the end of the pipe with one hand and hit the pipe with a decent sledgehammer with the other hand. You really need to put a lot of pressure on the pipe before you hit it or it won't work.
4. 3 hits and my bolt finally came loose and no damage was done - have driven 5000k's since timing belt replacement with no problems.
I know it sounds agricultural but after 6 hours trying to get that bastard bolt undone I would have tried anything!
Hope this helps.
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1464288
I saw a mechanic having a bad day one day and in his haste he held the bar up to the wrong side of the chassis rail....
Ended up with a broken pair of glasses and a busted nose..... It sort of went like this "watch how we do this you apprentices... *whack* - You *ucken mole"
Sumo
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1464440
Managed to do two within half an hour when changing the pulley arrangement over from my R33 engine to my R34 engine. Both out of the car, both jammed with a screwdriver.
What you need to do is apply a shock force as Marriott said. Applying a steady increasing force won't do the trick. Get an 18" bar and a gimpy/copper hammer and belt it a few times.
Here's a question, are you actually trying it anticlockwise or clockwise?
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1465470
Hope this helps.
That deffinetly did help! Thanks heaps worked a treat! I really didnt think id get it undone but you saved the day for me. Thanks mate!
Deren
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1466297
Now that Deren has the bolt off. How do we go about putting the bolt back on?
My workshop manual specifies the torque specs on the balancer bolt as 329-344 ft/lb or 446-466 N/m.
I have a huge 3/4" torque wrench with an 1¼" (approx 30mm) and with the car in gear the brakes hard on I can't put adequate force against it.. the driveline has too much slack and the car rolls slightly.
Whats the solution?? I'm thinking rattle gun at this point, even though I don't like the idea.
Cheers.
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1466557
Deren, glad you got it off.
I used the same method in reverse to do the bolt back up. Its such a large bolt with fine threads that there is no chance of stripping it, so I did it up as hard as I could with the breaker & extension and then whacked it a few times. Hasn't come undone so far.
Cheers.
https://www.sau.com.au/forums/topic/80128-ringgear-stopper/#findComment-1469703
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
    • If it does get a turbo it would blow the JCW Mini out of the water considering how "close" some of the tests were. Then again the Mini would probably get one of them Stage 69 tunes.
    • Next up, the extinguisher is mounted but really only temporary because I ran into clearance problems (the bracket fit fine....until I put an extinguisher on it). It picks up the seat bolt mounts but has long bolts running through 20mm spacers for now Doing it properly requires a bit of quick welding but I ran out of time, this will do for the practice day
    • Family events weekend but a snuck a couple of things in. NSW state champs were down at Wakefield so I got Gordon Leven's to bring some A052s down in the right size for some spare rims I had that "fit" (actually ex-Leaf Nismo.Rays in 18x7.5). Tyres are 235/45/18 so they are narrower than stock (19x8.5s) but I need to keep road tyres on it for daily use for now. In a first, those weird size tyres had been in the yoko warehouse for so long (4.5 years apparently) that they offered 4 for the price of 2....so 4 practice tyres for about $1100. Bit of a bargain for sticker tyres, considering the real purpose of the practice day is mostly to see how the various temps go (and the weather is due to help, forecast 32o). In terms of race wheels, it looks like I should be able to fit 9.5 fronts and 10.5 rears but 18 vs 19 height will be based on what tyres I can get in the right size - good tyres are very limited in available widths in diameters above 17" so some planning is needed. Once I'm sure this car will work I'll order a set of custom BC wheels like I did for the R32, you can get exactly the right width and offset to make the most of the available space in the wheel well (the 32 has 295s all round on 18x10s and they are awesome) Incidentally A052 are asymmetrical but not directional which is good news for rally use if the front and rear wheel sizes are different because I can swap them side to side on the same axle. Directional tyres are a nightmare with staggered size wheels because each tyre is fixed on that corner unless you can get it rotated on the rim (not really practical mid rally in most cases)
