Hey guys...just after a bit of advice...
am chasing any possible options 4 an auto gearbox 4 an R33 Skyline - 2 handle approx. 500rwhp & be used 4 both drag & street driving
1st option - keep standard gearbox & custom build with computer etc. = more money but keep the overdrive
2nd option - go with a C4 or similar - would be good 4 drag but lose the overdrive & i guess a lot of driveablity (4000+ rpm @ 100k's etc.) out of it
these are the only 2 options i have come up with so far - can anyone help with another solution that they know of? don't want 2 have 2 go with a manual gearbox either...
would appreciate some advice/help on this..thanx heaps :)
https://www.sau.com.au/forums/topic/80139-auto-gbox-4-high-hp-application/
ring phil on 0429477641 after 5
he built my powerglide
he also does 3 and 4 speed gearboxes
Thanx 4 that Jason...
i'll give him a call i think - after all i saw what ur car was capable of @ GCAS so i guess he knows what he's doing
join calaisturbo.com.au and ask them. plently of auto vl's using modified auto boxes to make stacks of power. i think the vl uses a jatco 3 speed box which you could probably even adapt to suit the r33. no idea on how strong it is vs the stock r33 auto box.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
    • I used to love stock take. I used to take f**k of a lot of stock. /Rodney Rude.
