Just wondering if anyone has done it on an rb20, or even an rb25?
Seems to be quite popular on the rb30et's with the r31/vl guys, and i can see the appeal as it gives a very small tract form turbo to filter (pod usually), and most claim that it reduces the inlet pressure drop in front of the turbo.
Plus u get a huge flutter on the rb30's, with fmic and no BOV, so would this be the same with a rb20/25 with fmic + blocked off BOV??
Please, no theories, just those that have done it, or seen it done....cheers :)
https://www.sau.com.au/forums/topic/80162-airflow-meter-in-cooler-piping/
The main reason people do it is to stop, or try to alieve the stalling problem associated with more boost and no plumback or atmo BOV etc.
Its an easy fix as a lot of west vic workshops really have NFI at times ive noticed.
Remembering a AFM works on unpressurised air.. putting it in the I/C tract will subject it to boost etc etc.
I have seen some AFM's play up after a while.
At the same time some dont. So luck of the draw i guess on that one
I can't really see that it would make much difference either way. If everything is running fine as it is I don't see much (if any) return for the effort of moving it.
Don't the VL's also have a more restrictive vane type AFM as opposed to the large hotwire unit on the Skylines?
Packaging is another reason I've heard people give for doing this too.
Actually, one of the benefits of the hot wire MAF sensor that's in the majority of factory cars these days is that it self compensates for differing air charge densities caused by variations in moisture, temperature and altitude. The principle of operation relates directly to the cooling effect of the air passing a heated wire of known thermal and electrical resistance. The cooling effect is a function of both air density and flow rate.
In theory I can see no reason why a MAF sensor shouldn't also compensate for any artificial compression of the charge air (i.e. ram pods, super chargers and turbo chargers) as well.
I would assume that the reason most manufacturors don't place these after the turbo charger is that they are very suceptible oil fouling and there is more likely to be oil in the charge air after the (oil lubricated) turbo.
Edit: I know the thread starter didn't want theories, but just my 2c worth :)
why you would want flutter i have no idea...
why dont u just take the intake piping off the car and hit the compressor wheel a few times with a hammer then put the piping back on and drive around its doing the same damage as the flutter
Edit:  I know the thread starter didn't want theories, but just my 2c worth :rofl:
hopefully SK sees this... very long ago he posted something further into all this which i cant seem to find :|
Actually that's not quite true. I am getting huge flutter now and the mods which could be contributing to it are:
1) Stainless steel intake pipe
2) large k&n filter (but will be replacing soon with smaller Apexi item).
3) Plumback / Atmo BOV.
I have not relocated the AFM, running a z32 in the stock position. However right now, my flutter would do many VLs proud. My bov is functioning as it should too. I guess the air that is being plummed back is hitting the turbo from the intake side, causing the noise.
ps. I do not want as much flutter as I have, mainly because I have kept the car reasonably stock looking, but if it's dosen't sound stock then what's the point.
Not really concerned with the flutter too much, but was wondering if the rlocation of the AFM to the cooler pipe giving a short tract from turbo to filter would 'contribute' to a louder/more high pitch flutter, like on the rb30's...... and, in-turn, if it's a worthwhile mod.
All ur replys have been great, but im still waiting 4 first hand experience :Pimp2:
I would like to reply, but I don't understand the question. It sounds like you want to stick the POD straight onto the turbo. But why would anyone want to do that when it is going to loose significant horsepower sucking all of that stinking hot air out of the radiator? I must have it wrong, surely?
The reason why the AFM is placed post intercooler is to remove the problem with reversion when running a big turbo/turbos. This causes idle problems, especially if there are big cams in there as well. HKS make a voltage smoother (EIDS) that fixes this problem if you don't want to relocate the AFM.
my cars been modified and havent had the computer put in . Im running a t04 turbo right now and with the afm in its origianl position i suffered from stalling etc. so i placed my afm just before my plenum only place i could put it wth my piping setup, this was before reading this thread its been like this for about a month and a half now, ive had no more stalling problems car runs fine but its only a short cut until i get the computer in, its not worth the hassle of doing.. but yes u get loud flutter,i dont get the deep noise but a high pitch pewww peww louder than the vl's but yeah. other than that its not worth the effort. also my turbo hasnt suffered even though yes they do tend to get shaft play i havent had that effect yet, and im running 12 psi atm.
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
