Yes, I have searched - but didn't find exactly all the stuff I wanted to know. So:
1) What is (more or less) max boost for standard RB20 Turbo ?
2) Will R33 FMIC piping work with RB20 or is the pipework different orientation ?
3) Is the front/dump pipe of an R32 same as an R33 ?
4) Is the R32 4door exhaust (cat back) the same length and orientation as a 2 door version ?
5) Is the GTS-4 suspension (front and rear) same as a GTS-t or GTR or neither ?
6) Can you disable front wheel drive ina GTS-4 same as GTR (by pulling a fuse , which one)
7) Will adjustable exhaust cam gear give same benefits as RB25DET at 4 deg retard ?
8) Is the exhaust cam gear same as RB25DET ?
9) Is the AFM in RB20DET same as RB25DET - and will Z32 AFM help with increased resolution ?
10) Is it worthwhile getting RB20 turbo hiflowed with new (steel) wheels ? At what cost ? Or is it simply better/less cost to get a 2nd hand HKS 2430
11) Is the RB20DET and RB25DET exhaust manifold the same ?
12) Is mounting a FMIC on the R32 similar to the R33 ? Do you need to shave the front bar ?
13) What can max power the GTS-4 gearbox handle ?
14) Does GTS-4 come with LSD at the rear ?
15) Is the rear diff same as a GTR (ie R200) ie if I found an R200 locker would it bolt up ?
16) Who does R32 ECU re-chips / how much ? Is it better to just get an SAFC / Fuel Controller ? I know this doesn't adjust timing - but was thinking the cam gear could take care of this for moderate power. (AP Eng PFC too expensive for an R32 - bad cost/benefit for the value of the car)
17) With GTS-4 do the same tyre width on all 4 wheels apply - like GTR ?
18) What is safe power (rwkw) for standard internals ?
19) What sort of brakes are on the front of a GTS-4 , I think 2 pot - Will the R33 4 pots bolt on ? What size discs ?
Sorry for all the questions , some might be rudimentary I guess....
Thanks in advance Roy - for your help on these (as I know you will know all the answers - he he)
CHeers,
https://www.sau.com.au/forums/topic/80165-more-r32-gts-4-questions/
1) What is (more or less) max boost for standard RB20 Turbo ? - 14psi
2) Will R33 FMIC piping work with RB20 or is the pipework different orientation ? - drivers side return pipe is different
4) Is the R32 4door exhaust (cat back) the same length and orientation as a 2 door version ?- 4 door is slightly longer
5) Is the GTS-4 suspension (front and rear) same as a GTS-t or GTR or neither ?-gtr i believe
8) Is the exhaust cam gear same as RB25DET ?-yes, inlet adj. cam gears are good as there is no vvt i think....?
9) Is the AFM in RB20DET same as RB25DET - and will Z32 AFM help with increased resolution ?-cubes is using a series 1 r33 i believe, and a z32 can be used as well...
10) Is it worthwhile getting RB20 turbo hiflowed with new (steel) wheels ? At what cost ? Or is it simply better/less cost to get a 2nd hand HKS 2430-previous owner of my car had this done, and it cost roughly $1100. It just made ~218rwkw @ 1.1bar recently on a tune
11) Is the RB20DET and RB25DET exhaust manifold the same ?- yes
12) Is mounting a FMIC on the R32 similar to the R33 ? Do you need to shave the front bar ? - yes
16) Who does R32 ECU re-chips / how much ?- Dr Drift...on these forums
I hope i got most of those right :cheers:
3) Pretty certain they are the same.
5) Same as GT-R
6) Yes
13) I'm running 180 Awkw through the stock gearbox
14) Viscous LSD, I believe
17) YES
19) 4-spotters front, 2-spots rear, probably the same as R33. A set of slotted rotors doesn't hurt.
