Hey guys i have a R33 gts-t Automatic, its having some weird problem, i have no idea what it is
it started happenign yesterday, the car will only seem to go to gear 2 highest when appling acceleration, i.e if i floor it, it will only go to redline in gear 2, and just keep bouncing off the rev...it is in Drive...
when i let go, it goes into gear 3 i believe, but as soon as i apply the slightest throttle...the car goes straight back into gear 2, ?
its as if its slipping? i put new automatic transmission oil in, but the oil got burnt straight away...no idea?
anyone no? please help! i hate it
You need to have it pulled apart by an Automatic transmision mechanic.
Did it make a bang when it started?
Or a crunch?
It will get worse and is always better to have something looked at rather than wasting money on little things to dogey it up in the short term.
na dont remember any large bang or crunch at all...drove it perfectly fine to my mates house, turned it off...
on the way back, tried boosting it, wouldn't go past gear 2 while accelerating, how ever it goes perfectly fine into 3rd and 4th while theres no acceleration applied and just let it roll??
I'll try to do a oil flush and let ya no
thanks
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
