I recently was on bridge road to pay my parking fine. I parked the car, went in and paid and when i came out about 10 mins later there was a deep n long scratch from the fuel cap till the rear lights. I reckon some guy in a jeep or sth scraped my car when he was parking or something. I was cut as and when i went to a panel beater the guy told me it would cost about 500. I reckon thats quite pricey.. What do u guys think? n should i fix it? Im quite tight on cash now and i was thinking of just putting some paint on top of the scratch to prevent it from rusting. What do u guys think i should do? thanks in advance
https://www.sau.com.au/forums/topic/80202-scratch-dent/
I'd put $500 towards performance mods personally :( But my car is battered like that and needs a full respray which I won't ever afford heh heh.
If it bothers you do what Method said and shop around. Even bullshit if you have to "this bloke said less" and be prepared to walk away till you find the place that feels good and gives you a good price.
I would also consider asking in the Vic section for recommendations because good panel beaters are a hit and miss affair so you want someone that won't have your car for 2months then not colour match the repairs properly.
Bad luck on the hit - better luck next time :P
https://www.sau.com.au/forums/topic/80202-scratch-dent/#findComment-1459060
Try www.chipsaway.com.au - they're pretty bloody good, and a lot less than panel beaters. Took care of 2 NASTY key marks on my car. I think they charge about $150-$200 per panel and they come to you.
I know a few other people that have been pretty happy with their work too.
Sorry to hear about it, but good luck :O
https://www.sau.com.au/forums/topic/80202-scratch-dent/#findComment-1459558
    • If there's a next time, next exit after mine is Costco 😛
    • OK. But what about parts of the block that, when assembled, were twisted into a position that pushed into the void space, which, when disassembled, then released that force and opened back up, thus putting the grout into tension? Would effectively just pull the cast iron off the grout at the interface, leaving a tiny void and benefitting not much at all. Swings, and roundabouts. It's like putting something tiny into the fleshlight and finding out you needed a smaller one, to perhaps follow your area of expertise.
    • Nah. You buy a kit that has shorter tubes.
    • I didnt present too many conclusions because I wanted your opinions and feedback based on your own experiences. I don't know the exact material, but it is similar to concrete and therfor only has valuable strength in compression. The forces on the set material once the head is removed would mostly be in compression since the grout wants to retain its shape and the block wants to return to its relaxed state since it's still within the elastic region. The grout would theoretically make the block more rigid. The exact amount would take a better setup on my end. Thought experiment: Instead of aliens, twist your favorite fleshlite. Now fill it with grout and allow it to sit for a week. Now try to twist it again. Observe what you see. Now get your other one and blow into it. Observe what you see. Now put it into a can and fill the space between your fleshlite and the can. After it sets blow into it. Less movement in torsion and less expansion i hope.
