Hey all,
Quick question. I drive my R33 GTS-T to work every day, and I am amazed at how bad the fuel consumption is. At the moment I am getting about 350klm out of a 60litre tank!
I have run my car on a dyno before and it was indicated that my air/fuel ratio was rich. I also have purchased a Blitz SBC ID-III, but have not installed it yet.
Would I gain better fuel economy if I installed the boost controller and wound down the boost to 0psi? or am I better off gettin an aftermarket ecu or something. My problem is that the car is auto.
Any suggestions on increasing my fuel economy would be greatly appreciated
Thanks all.
BOOMAU
1993 Skyline R33 GTS-T Series 1
Pod Filter
HKS Exhaust
Everything else stock
146.5 kW
https://www.sau.com.au/forums/topic/80210-installing-a-sbc-id-iii-for-economy/
No you won't as you can't wind it down to 0 psi. The lowest the boost will go is whatever the stock boost is as regulated by the actuator. The way to improve economy is by using a light throttle, making sure you've got goo d plugs, making sure your air filter is clean and your oil is clean. Rish running is usually the result of dirty air filters.
Don't put your foot down as much, be more 'even' in your driving.
If you want 0 psi you would have to wire your wastegate open so it's never letting it build boost.
Also - don't put your foot down more than it needs to. e.g. you're going up a hill and you put your foot down and 2cm into depressing the pedal your car stops moving any quicker. Take your foot off lightly to 1.9cm (for example) and your car doesn't slow down. This is optimum.
What about the the good old O2 sensor. There is a thread on it in ths forum It appears that heaps of people got similar fuel consumption to you (mine is actually even worse I get 350kms on a lucky tank) and after changing it they get around 500km a tank easy driving. Apparently if this sensor is broken the computer runs rich to protect the engine cause it doent know how much air is coming in. I am getting mine changed next tuesday so hopefully it works for me!
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
