Hey all,
Quick question. I drive my R33 GTS-T to work every day, and I am amazed at how bad the fuel consumption is. At the moment I am getting about 350klm out of a 60litre tank!
I have run my car on a dyno before and it was indicated that my air/fuel ratio was rich. I also have purchased a Blitz SBC ID-III, but have not installed it yet.
Would I gain better fuel economy if I installed the boost controller and wound down the boost to 0psi? or am I better off gettin an aftermarket ecu or something. My problem is that the car is auto.
Any suggestions on increasing my fuel economy would be greatly appreciated
Thanks all.
BOOMAU
1993 Skyline R33 GTS-T Series 1
Pod Filter
HKS Exhaust
Everything else stock
146.5 kW
https://www.sau.com.au/forums/topic/80210-installing-a-sbc-id-iii-for-economy/
No you won't as you can't wind it down to 0 psi. The lowest the boost will go is whatever the stock boost is as regulated by the actuator. The way to improve economy is by using a light throttle, making sure you've got goo d plugs, making sure your air filter is clean and your oil is clean. Rish running is usually the result of dirty air filters.
Don't put your foot down as much, be more 'even' in your driving.
If you want 0 psi you would have to wire your wastegate open so it's never letting it build boost.
Also - don't put your foot down more than it needs to. e.g. you're going up a hill and you put your foot down and 2cm into depressing the pedal your car stops moving any quicker. Take your foot off lightly to 1.9cm (for example) and your car doesn't slow down. This is optimum.
What about the the good old O2 sensor. There is a thread on it in ths forum It appears that heaps of people got similar fuel consumption to you (mine is actually even worse I get 350kms on a lucky tank) and after changing it they get around 500km a tank easy driving. Apparently if this sensor is broken the computer runs rich to protect the engine cause it doent know how much air is coming in. I am getting mine changed next tuesday so hopefully it works for me!
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
