hi
Just recently my car has started playing up, a couple of times I started it up only 2 or 3 times it didn’t want to accelerate, it would but spluttering all through the revs,
Now it got better but it still splutters around 4800-5000 for a split second every time I run the car on the road, only does it 2nd gear onwards (doesn’t do it in 1st)
it splutters more when it cold
Can’t find out what the hell is wrong with it, giving me the shitt !!!!!!!
any idea??????????????? it's a 1997 R33
thanks
https://www.sau.com.au/forums/topic/80216-help-engine-isnt-running-so-good/
does it miss-fire ?
can you explain splutters more
"splutters, like it's missfiring" i've checked all the spark plugs and coil packs they all look good, after it splutters around 4800rpm it revs through to near red line as normal
i'll check the stock i/c pipes as IMACUL8 said cherrs!!
and i found a site that tells how to check fault codes, i'll check this out :run:
thanks for the reply's :O
im getting that at the moment too, around the same rpm range, just like you said it splutters then rev normal, im pretty sure mine is related to my plugs, im going to take them out and check if i foul them and if not regap them,
have you regap ur plugs?
then your plugs (as long as there all good) are not your problem.
Look at AFM? or air leaking from pipe work. Also fuel pump might be playing up. Its always wise to change out the old one for a bosch, walbro, gtr fuel pump.
standard gaps are like 1.2 i think but hey are fine unless u run over a bar of boost. Unless ure plugs are coverd inblack gunk they should still be fine and they would ping like crazy at high load/revs.
It sounds electrical, try jiggling ure plugs and what not it could be ure coil packs as mentioned before. make sure everything has a good connection.
If u get it to about 3500-4000 and cruise and pump it up and down does it still do this?
oh yeh and just thought id check, u havent been "detailing" ure engine bay recently have u? the valley is filled with water? it happens.
about a week ago it was really bad across the revs but know it only seems to be up the top end, above 4500ish
i did actually give it wash about week and half ago, but it was playing up before that, and i have pulled every plug including the coil's pack plugs and sprayed contact cleaner, since i washed it
thinking it could be the fuel pump or fuel filter, will have a look when i get home
Big mystery :confused:
get your fuel regulator / fuel pump etc checked out
could may even be your tps.
do you find this problem does not happen when youre car is fully warmed up?
or happens alot more when you cold start + drive?
I only give it a bit of throttle when she is warm (it only seems to happen about 4500ish )rpm
i drove her last night seems to be getting better
each time i gave it a bit of throttle it was less noticable
i'm going to buy a fuel filtter today after work (i'm regap the spark plugs on the weekend)
see how it goes :)
ive got similar probs on my NICS RB20DET, only really has started since I upped the boost (10psi). Basically it sort of hesitates as it hits peak boost, not a total cut but certainly not smooth. Its not pinging (has cooler with the piping thermo wrapped). Im thinking its either ignition or fuel based (not getting enough fuel on boost) but I have already richened the mixture a fair bit and this has still hoped. It idles fine and off boost it runs fine too. Time to test the coil packs (i have some spares at least) and do a plug change. Whats the easiest way to test the coil packs?
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
