Radiator from Race Radiator 40mm With Silicon Hoses
Excellent Condition, no bent fins.
$500 delivered
Cusco Front Pair Pillow Tension Rods
FEATURES
Reduces the amount of suspension flex during
hard cornering.
Increases greatly the handling response going into corners by adopting pillow ball mount on the body side. High rigidity pillow rods balls used to hold down tires under braking. Increases straight line stability by reducing toe out and friction.
FITTING
A simple bolt-on type easily converted from
manufacturer's products.
ADJUSTMENTS
The turn buckle type allows simple
adjustments with the parts on the car.
DURABILITY
The pillow balls are covered by rubber boots
for increased durability.
$250 delivered
Cusco Rear Strut Brace
$150 delivered
HKS OIL TEMP Mechanical
Brand New
$125 delivered
HKS WATER TEMP Mechanical
Brand New
$125 delivered
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
