Santhas,
My VS appeared to handle the stock power level + an exhaust fine, it was only once I threw a mild cam and ecu in to it when thigns started to break.
My diff went, didn't clunk, just bearings began making strange loud noises that made it sound as if it was going to lock up and send you in to the guard railing any minute, it also was openwheeling, the gearbox went on a hard launch against some crap HQ V8 4speed thing.
Funny thing was as I was trying to work out where my gears had gone I saw the sticker on his rear window "Classic not plastic" as he roared past.
I drove it the same as I have the skyline, I have now eased up on the skyline as i'm not as much of a hoon as I was when 19.
The VS had IRS, comparing the designed and look they look weak, its apparently a common problem for the rear subframe to split from the diff mount bolt holes when you start putting some decent power through them.
It was lowered with bilsteins, whiteline shocks and sway bars, it also had a whiteline camber kit on the arse end, who knows maybe lowering the IRS VS commodores and slapping the camber kit on them places too much strain on the subframe.
BUT it doesn't really explain why it split the subframe like a can opener attacked it from the diff mount bolt, I still suspect as suggest to me when it happened that the rear ends on them cannot handle big launches and hard gearchanges when making decent power.
Not stock power, as really whats 130rwkw. :P Stuff all. lol
Edited by Cubes
  • Replies 173
Man, sounded like something really went pear shaped...
The real question is, why did you give it to it when lining up against the HQ? Can't believe what a massive failure that was though. Ahh well, at the moment i'm seriously open minded about what car to get next.....about 15k budget.
These theads always suck when people post replys with no evidence just they just post what they think would happen.
r33 gts25 vs any non supercharged v6 factory commodore would be close in stock vs stock form exept for maybe the new vz with the new all aloy 3.6ltr V6 they go a fair bit better than the old 3.8's the factory claimed times are very similar.
As for a 3.5ltr magna beeting a auto r33 gtst id doubt it mate.
Warren you need to relax :)
I only 'ever' type something if I am confident in what i am saying, the problem with all these kind of threads is people like yourself (and ARKON) compare modified Skylines with Standard competitors making any comparison totally irrelevant, liner32 in his first post said the R33 has an exhaust otherwise stock...why then assume its modified and say it'll beat a V6 or V8 VT Commodore..?
Arkon from your sig I can see your car is hardly standard, hence i'm sure it would beat a TJ Magna, my 'standard' Magna ran a 15.8, a 'standard' R33 GTsT would be no quicker :D
Standard R33 Gtst auto sedan runs 15 flat.
So your magna is 0.8 seconds off at around 160km/h and about 3-4 car lengths behind... so in fact a "standard" skyline GTST sedan is significantly quicker than any "standard" Magna, end of...
Edited by godspd
Have a go at people for stating opinions with no evidence, then you come out with an opinion with no evidence! Being a little hypocritical aren't you?
I think the comparison was with a GTS and a 3.5 Magna, which is a more suitable comparison.
I'm unsure what model a TJ is but I do know the new magna's do go very well, I've driven a NA R33 back when I was looking at my R32. Sorry to say manual for manual the Magna will easily kill the R33 NA, especially from a standing start to 100km/h. Drive one and you will know what I mean. The power delivery and flexibility of the motor/gear ratios makes the car quite zippy and fun to drive.
My other halfs brother often brings the new mitsi's home from his work, they go very very well, especially the manuals. So much torque down low from such a small motor.
Edited by Cubes
Mmmm despite the claimed power outputs of the VZ, the 175 kw version is very doughy, although the 190 kw version is very very quick. Dont know why but there seems to be more then a 15 kw difference between the two.....
As to the NA 3.8's verses GTSs, well my VP must be a freak, or the previous owner cammed it without telling me (15.4 1/4), but I know without a doubt there would be no comparison between the two. The massive torque available from down low in the range is enough to get the jump, and the GTS just doesnt have the top end to catch it.
But in the looks stakes......Vp Wagons unfortunately dont go down well with the fairer sex....
That is one quick VP. My mates got one and it is fast but not that fast. Though he says he has raced an NA R33, and beat it without too much trouble. I think it was an auto. His VP is a manual with just extractors & zorst.
LOL...I know its a Skyline website but it still amuses me how people will overate standard Skylines sometimes, a standard auto GENIII VT would cream a standard auto R33 GTsT :)
My TJ 3.5 Auto Magna would cream a Standard R33 auto GTsT :O
Yeah sorry dude but my GTs-T blew the pants off of both a 3.5 Magna and a
GenIII
I mean GenIII still use push rods dont they!?
But sad to say that i think the N/A skyline would have its work cut out for it.
But good luck dude.
Saw a dead stock looking VS V6 Auto commodore with P plates stuck on it at Mildrens yesterday.
Walked around to the front to see 2 turbo's bolted on to each bank.
The thing made 240rwkw at 8psi and just over 300rwkw on 12psi. :O
Edited by Cubes
Commodores are shit and non turbo skylines are shit!! stick with boost :P
Greg
You must be the brains of the outfit. Cars are cars. Each with their own different qualities. Skylines are fast and nimble, Commodores are more practical and cheap.
Maybe not that fast anymore. Damn clutch has ruined thrush bearings. New brakes today though :) But i think it would still crack a 15.6 at least. Note to kids: Do not attack your own heads with a dremel, it can lead to unpredictable results..... Like saving nearly a second off your ET.
Maybe not that fast anymore. Damn clutch has ruined thrush bearings. New brakes today though :P But i think it would still crack a 15.6 at least. Note to kids: Do not attack your own heads with a dremel, it can lead to unpredictable results..... Like saving nearly a second off your ET.
Yes I understand that there are different cars for different applications. Eg. I have a modded skyline for Sundays and looking for a Van as an everyday.
Overall the build quality of commodores is very very poor. My dad has worked for GM for the last 20 years and is currently a leading hand engineer working in mechanical engineering and robitical engineering (what ever all that means) but he tells me on a day to say basis how poor the quality is and how it is just getting worse as more cheap imports come in.
Each to there own..
Greg
Each to there own..
Greg
Yes i agree with the build quality. My dash is falling apart..... But I had $5000 to spend on a car 3 years ago, it was fast, it was in good condition, so i thought it was a good deal. Given the oppurtunity again I probably wouldn't have bought it again, maybe saving a little more for a R32 GTSt or something. Which is what im saving for atm.
These days the build quality of cars such as Land Rovers (I worked at a Land Rover servicing place for a while) is decreasing, almost to coincide with warranty running out. (A new mirror and servo's costs about $1600 for a Discovery 3). Thats how they're making their money unfortunately.
But yes i agree on the Skylines being better built cars. Although it wasn't particularly fast, the NA R33 i was in was solidly built, and looked great! Hence the reason I want one.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
