Hello, gents and ladies, I have a question about the sensor which bungs into the bottom of the r32 radiator? Anybody have any idea as to what this item is for? I have just a bought a bigger radiator, and am wondering if it needs to be bunged in or if it is not really needed. Any help and disscusions on this would be great.
Thanks in advanced.
Bill
https://www.sau.com.au/forums/topic/80261-senor-on-radiator-r32/
It Is A Coolant Temp Sensor I Reccomend Puttting It In As It Gives U The Reading On The Temp Gauge On The Dash
How On Earth Do You Do That?
Back to the point - it's got nothing to do with the gauges. It's a thermal switch for the A/C cooling fan (the one out front of the A/C radiator).
a/c radiator its called a condensor the one on the actual radiator (filled with coolant) is a coolant temp sensor which tells the ecu how hot the engine is
blind_elk is correct....it is a thermal switch which activates the aircon fan for extra cooling in the event that coolant temp gets too high.
