Yep, I'd like to know the question aswell.
My climate control in my R32 has never been working right since I got the car.
I've had it retro fitted, regassed and temp sensor replaced but it still blows hot air all the time. I get around it by using the windscreen option (for some reason it actually blows cold air from that setting).
What do i have to press on my Climate control so that i can tell what is wring with my air conditioning?
Within ten seconds of turning the ignition switch to on keep the automatic air conditioner switch OFF depressed for five seconds.
If there is something wrong an error code between 21 & 27 will come up on the display. If 25 comes up go and park the car in the sun. Code 26 is the PBR sensor. If it has failed the Humphrey will pump hot air all the time.
while we're on the subject... where is the inside temperature sensor (behind the little vents at the bottom right of the centre console maybe?)? and where is the ambient sensor on r32s?
inside temp sensor is the little holes next to the ashtray on the contre console
amb temp sensor is on the front of the car near the horns
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
