Found this at Auction.
Engine bay looks tame, but this is the translated description.
From Yamaguchi prefecture H 7 year ECR 33 reforming (structural change * motive for action machine * width * length * height other things) engine: Turbine * HKS 2835 intercooler * HKS exhaust type above RB30 presumption 400 horsepower: Front pipe 90mm sport catalyser - HKS hyper muffler drive system: The NISMO non pickpocket (3 stages it changes) ƒjƒXƒ‚ G attack new model (the twin plate) the underside: ƒI[ƒŠƒ“ƒY height pitch (damper 20 stage) the spring rate F16R14 (the brake rotor pyro tension rod for normal it is) 17 inch (before) the tire: BS 01275 * 35 * 18 wheels: Wise 10.5 J~ 18 (Off28) meter: ƒjƒXƒ‚ 300Km/h reinforcement: Approximately under arm being attached wrapping: Wise JGTC model (' 98) as for travel distance with first engine with approximately 70000Km present engine approximately 10000km
Look at the height from the car to the ground, but look at the wheel arches! Imagine if you lowered it further, it'd be on the ground!
Interesting :)
Current price is 2,300,000 Yen with 2 days remaining.. Wonder what it'll sell for?
  • 4 months later...
i like it a lot... lol I was tellin inark that instead of buyin an r32 GTR i wanted to get an R32 GTS4 and do exactly the same thing. get a widebody bodykit and an RB25/RB30 hybrid.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
