PRICE DROP to $17,890 Negotiable.
Hi All
Just testing the waters to see whether there is any interest in my car. Another car that i could possibly like has come up, but if nobody is interested in my car, i will just keep it and modify it more :crazy:
Its a White 1992 R32 GTS-t M-Spec
180,000km
Manual
Turbo
R33 Rims (Falken Azenis RT-215's on the Rear)
R32 GTR Aluminium Bonnet
GTR Grill
GTR Skirts
Rear Spoiler Removed
Paint in very good condition, well looked after using quality products
Good condition Interior
Lowered/Stiffened Suspension of Unknown Make
Front Strut Brace
Rear Strut Brace
Race Brakes RB74 Brake Pads on Front
Motul RBF600 Race Quality Brake Fluid
Very Heavy Clutch of Unknown Make
K&N Pod Filter
Flying Performance 3" Dump/Front Pipe
3" Highflow Cat
Kakimoto 3" Catback Exhaust
GTR Steering Wheel
Autometer Boost Guage
Concealed GReddy Turbo Timer
Genuine Skyline Floormats
Nismo Leather Gearknob
New Leather Gearstick Boot & Handbrake Boot
IMPAKT's NissanDataScan module
Probably a few things i've missed, but you get the point ;)
NEW PRICE: $17,890 Negotiable.
I know this is more than other R32's, but its also in alot better condition than alot of R32's, and i feel that its worth alot more than this! ;)
Can be contacted at Jwgeh@tpg.com.au or on 0402 202 978, or by PM here.
I can attest to the condition of this car. Completely immaculate and always cared for. Also the owner is the softest driver I've ever met, my grandmother gives her car more than Jason so it's definately not been thrashed.
The car drives well, runs well, body and paint is superb!
I stuck with the stock rims due to the weight difference between them and most other 'larger' rims that most people seem to get (and also the price difference between 16" semi-slicks and 18" semi-slicks). The less weight (unsprung weight) the better the handling.
However, if you really are interested, i'm sure some "bling" 18's could be arranged
  Are_thirty_two said:
I guess thats a pretty fair response. but i think it wouldnt hurt for some wider wheels, maybe 16x10s for even greater handling
I've dropped the price to a more realistic figure, however, in my opinion its worth more than this.
Price Drop to $17,890
Any interest? I've got until probably Tuesday of next week to make up my mind if i want to keep it or sell it, as its booked to get $4k worth of suspension upgrades done to it. Now, i don't really want to put that on and then sell it, as its a bit pointless...
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
