as above i live in england and the forums in england no one seems to help!!??
i have a r32 gtr and im having some problems. its running 400bhp+ with a few mods. cut a long story short i have had the car for a few months no problems running sweet as a nut, then a slight miss occured only under full throttle above 5000rpm, everyone said coil packs which i still think it is.
nyway my rad blew up so i got a new 1, then i realised my water pump had gone so i replaced that. got car running again. my car is not over heating but seems to be runnig ever so slightlt warmer but there has been an increase in the weather.
people r saying that my head is cracked ? could this be? there is no loss in performance not drop in oil pressure and no mixture of oil and water.
the car from day one has bubbled after driving hard and been parked up and is still doing it now could this be anything to do with it?
would really appreciate some help need to get sorted
https://www.sau.com.au/forums/topic/80328-urgent-help-needed/
If you have a cracked head or a blown h/gasket you will be loosing coolant , the coolant level will go down bellow the low level in the plastic tank .
How do you know its running hotter ? do you have a reliable temp gauge ? power f/c ? Or you just look at the stock gauge ? When the stock gauge is in the middle the temp can vary from 80- 105 degrees !
When you replaced the radiator did you use the same one ? same size core ? smaller / larger ? Is the auxiliary fan ( air cond fan ) connected ? is the clutch fan working ?
Did you find out the reason the rad blew up ?
It might simply be that the system has not been bled properly and/or there are blockages in one of a miriad of pipes caused by corrosion. The bubbling suggests you have air pockets or hot spots in the system. I would suggest a complete drain and flush is required (inc removal of the block drain) followed by a careful refill and bleed.
is there no other reason for slow loss of coolant other than cracked head or leaking gasket? I have a very gradual loss of coolant...can't see any coolant leaking etc....the car is coming up to 100k so am looking at replacing water pump and pipes....just hope i don't have a cracked head.
There is no coolant in the engine oil and my gasket was replaced recently.
never found out why rad gave in there wasnt any rise in temp so just put it down to being 16year old, replaced with same size core.
i only have two fans the main one and air con one both working fine.
im just reading the stock gauge.
is there any definate checks i can do for a cracked head/gasket??
cheers for the replys much more help than england.
the bubbling only seems to occur after driving hard?? ive tried bleeding from everywhere?? this cars is doing my head in!!
a radiator shop should be able to do a test where they can check for hydrocarbons(fuel) in the water, the test solution changes colour when hydrocarbons are present. can't remember the name of the test but they hook up the tester where the radiator cap goes.
Also are you sure there are no leaks from any of the other hoses not being tight enough. don't forget to turn heater on fully when bleeding the air out of cooling system if you do it yourself.
A pressure test will tell you if you have cracked head of blown h/gasket .
Have you checked the radiator cap ?
You cant go on the stock temp gauge , you are going to have to test it with a known good gauge then you will see what the temp gets up to .
found a tiny hole last night in new water pump!! long story anyway sorted and my heater is working now not just on FH like b4. but the worring thing its still missing and bubbling after a hard drive. the missing is wen it gets hot and its after 5000rpm at full throttle not half throttle??? is this signs of a crack opening with heat? tried changing one coil pack at a time and no joy. my local mechanic says its def the head cracked or gasket?? cheers for ur replys
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
