Hey All
I fixed all my problems and the car was running great for aboout 2 dayz
i was driving it yesterday and now it makes a huge whining noise in the turbo. noise the air sucking noise like a loud whines, and it does not boost at all?
its like the air isnt goint through the turbo.
Any Ideas? Also thre is not smoke
It is an r 32 turbo, if i seem to be f$%ked i will replace with an r33 turbo, so if anyone has one goin for cheap let me know please.
https://www.sau.com.au/forums/topic/80383-whinning-noise-from-turbo/
Found the problem.
Pulled the turbo off and found 3 of the teethe on the exuast side ( the wheel ) where stuffed.
I am now opting for a r33 turbo. I would go high flowed or someting with a litle bit more power but the car might be getting sold soon.
Thanks for all da help.
P.s I assume the r33 turbo had ceramic parts as the r32 does? ( I have now learnt why people go for steel parts.)
  • 3 years later...
i have the same problem...but exhaust wheel/s are fine..
ive just put on my second turbo....
but still ot the turbo whinning problem...
anymore ideas?
turbo bearings..from oil shortage..like from a blockage in the oil feed lines mayb?
wastegate actuator not opening???
anymore ideas???
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
