FS: GTR parts, standrd turbs, injectors, AFM's + +
Skorj just for info to help your injector sale. The crack you speak of sounds like it is just the pintal cap. I pay $1.60 for these direct from the main injection supplier here in Brisbane. It just needs the old one pushed off and the new one pushed on in its place.
Re: R33 these injectors will not fit the standard fuel rail as R33's take side feed injectors the same as sr20det's, BUT just like sr20det's, (When fitting bigger top feed injectors such as RX7 series 4/5 ones), you can get a replacement top feed fuel rail and then they will fit, and you need to run resistors as R33 (GTS-T's) take hi impedance injectors.
  • 4 weeks later...
all pm's replied....
everyone enquiring about injectors== i have told everyone who has pm's me that one of the injectors has a crack/chip in the platic cap arount the tip of injector (injector itself is perfectly fine....)  which i ddint discover untill a few days ago...
this shouldt affect performance as they were working just fine in my 240rw/kw gtr from which they were very recently removed..  but i'm sure if u felt the need to replace it, it wouldnt break the bank....    (feel free to to post here if i'm wrong)
i will post the injectors anywhere in aus for free to make up for not stating this in original post.. and round it to $250
I'll take them if they're not sold. Send me and email [email protected] with your bank details so i can deposit the dosh
Cheers
 Share
    • 350/370Z CD005/9 seem to be a good choice, but you'll need to address the diff ratio issue.
    • Brand new r34 gtt box
    • What is the go to gearbox these days for a RWD RB? Back in the day VG TT boxes were cheap and strong. Seems they are as expensive as an RB25 box these days. What are the options without remortgaging the house?
    • Define "Nissan big brakes". You just mean standard R34 4 pots? And...it's not even the offset you need to worry about. It's really a detail of how much clearance there is between the caliper and the back of the spoke/face, which is affected more by the design of the spoke than it is by the offset. If you think about it....take any wheel, say a 19x8 that does fit and clears the caliper. Then add or subtract an inch of wheel on the outside, without changing anything else. You have changed the offset by half an inch, but not changed the clearance situation at all. Same for if you add or subtract an inch from the inside edge. The way for you to work this out is to take a wheel off the car, grab a straight edge and a ruler or two, and start to measure the distances from the wheel mounting face on the hub to the outer face of the caliper, and the outer diameter (that faces the barrel of the wheel) of the caliper. Armed with these dimensions and any other measurement that grabs your fancy while you are there, you can then go to the seller of the wheels and do the reverse measurements from the wheel's mounting face and see if there will be clearance to the caliper. There really should be. I have 17x8 RPF1s +35 clearing the caliper face by a finger tip. Those wheels do have pretty thin spokes with some curvature.... but then so do most wheels to suit Jap cars.
    • So I’ve got a r34 sedan that I managed to get green stickered, meaning I need to go through government approved wof station for my car to be allowed back on the road for some reason my car is certed for 19x8 rims.. I need these wheels  does anyone know what offset will be fine to clear Nissan big brakes? I saw 35et for sale near me, I can’t drive the car to test fit or risk being fined ..   I searched heaps online couldn’t find anywhere..
