think thats your problem Jackie, rears should only be 5w ..
oh really my rears are 21w. ill give that ago before i go out n get a new flasher unit.
Mine flash that fast that i counted about 30 clicks in 10 secs
Jackie,
On the way home from work today I dropped into a car yard and checked the left rear bulb in an R33 (yeah, don't ask). It was 21W. By the looks of it I think there are 2 bulbs per side (in the rear) and maybe the other one is a 5W. This is the case with the R32 front indicators, the main is 21W and the minor is 5W.
I disconnected the 5W bulb in my R32 and couldn't detect much if any change in flasher speed. After reconnecting it I then removed the rear 21W bulb and connected a 5W bulb but couldn't detect any real difference in flasher rate. This confirmed my suspicions that you need a significant change in current draw to noticably change the flasher rate. A good example is replacing the bulb with an LED. I did this on my Yamaha R6 and had to make up an additional circuit to correct the flashing rate (it flashed real fast).
This is pointing more towards the flasher unit. It would be good to borrow one from another R33 to check before forking out good money. Autobahn advised that flasher units range in price from $25 to $38.
Cheers,
Ben
i tell you i give up with it lol
its goin into the mechanics next month for a timming belt change so ill just get my mechanic to figure it out. Atleast the flasher unit doesn't cost that much so if it needs replacing i dont mind forking that much out for it.
Ive been looking at this thread over the last few days because I had the quick indicator problem.
My indicators only started going quick ever since the bodykit was done (400r front). Anyhow, I took a look at the blinker bulb today, and it was 5w 12v. I replaced it with 21w 12v globes today, problem solved :)
Thanks for your help guys :)
Jason
Jackie,
I've been dwelling on this topic for a while now as I'm not convinced the faster flashing is due to the flasher unit (I have never had to replace one in the past). I was lost for ideas and its difficult to diagnose a problem without a wiring diagram.
My brother-in-law mentioned the hazard switch in their old 33 had been a problem for them which got me thinking. If you disconnect the hazard switch completely the indicators won't work (from memory) which may indicate that the switch is in series with the indictor switch (ie the power feed goes through the hazard switch before/after the power feed to the indicator switch/stalk).
It could be possible that the hazard switch is adding extra resistance to the circuit (eg due to worn contacts) causing the faster flashing rate. It may be something to mention to the mechanic.
Without fulling understanding the circuit (lack of wiring diagram), solving these problems is usually a trial and error process.
Some food for thought.
Cheers
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
