Full Rebuild, with most receipts done 3000k's ago.
JUST ABOUT EVERY GASKET REPLACED
FUEL INJECTORS TESTED AND FLOWED
BLOCK ACID WASHED
NEW WELSH PLUGS
ARIAS 88MM FORGED PISTONS
HONED AND BORED 40 THOU OVERSIZE
MATCH PORTED MANIFOLDS
NEW DRIVE AND CV BOOTS
STAINLESS DUMP PIPES
STAINLESS FRONT PIPES
NISMO N1 TURBO'S..RATED 400HP EACH
NISMO N1 OIL PUMP
NEW CRANK ANGLE SENSOR
OS GIKEN CAM GEARS
OS GIKEN TWIN PLATE CLUTCH
LIGHTENED FLYWHEEL
HKS POD FILTERS
HKS BOOST CONTROLLER
HKS TRIGGER SYSTEM
TRUST INTERCOOLER
ARC BOV
GATES RADIATOR HOSES
GATES TIMING BELT
NGK IRITOP SPARKPLUGS
REMOTE OIL FILTER RELOCATOR
REMOTE OIL COOLER
HKS FULL TRIGGER SYSTEM..BOOST CONTROL
APEXI REV SPEED METER
IN DASH DVD PLAYER
IN DASH CLARION LCD PULL OUT SCREEN
12" SUB AND AMP
RELOCATED AIR CONDITIONER MODULE IN GLOVE BOX
VEILSIDE GEAR KNOB
RAZO PEDALS
BLITZ BOOST GUAGE / TURBO TIMER
PIVOT SHIFT LIGHT
ISOTTA STEERING WHEEL
SPEEDO CHROME SURROUND
RETRIMMED DOORS
GENUINE APEXI MAGS 17" X 9"..RARE AS
NISMO BOOT LIP
N1 FORNT BAR SLOTS
TRIAL SIDESKIRTS
BOMEX REAR PODS
The cam gears are still not set as I need to get it done properly so there is still heaps of power to be made in tuning.
Lights up the rear wheels just driving it normally without clutching it in RWD.
Chasing $32000 which is what the car yards are offering and I'd rather keep it if I don't get that as I put so much into it.
[email protected]
  • 7 months later...
  • 3 weeks later...
Dude if it lights up the rear wheels with 4wd engaged,,, then ur 4wd system isnt working properly. get ur transfer case checked they wear an need rebuilding, its quite a commen thing.... if its working properly it wont spin any wheels unles ur makeing 500 kw the wheels,, and then it will spin all 4 if ur lucky not just the rear......goodluck mate :P
Slogtr, mate your wrong with the back wheels lighting up my mate at works got a 350rwk R34 GTR Vspec and it lights up the rears it's only has 38k on da clock so it cant be worn out!!
Rick all the best with the sale !!
I sold my S2 R33 that only done 50k and was a true 4.5 grade and still ppl knocked it!!! dont post stuff unlesss it helps out the owner cheers
We ll said r33s2xxx mine lights it up first and second gear coming on boost, but then the front kicks in, and if i put on rwd it will light it up in third as well,
Good luck with the sale,
It sound like a quick car
Sorry, I should clarify...I meant in 2wd and reading back, I thought it was what I said.
"Lights up the rear wheels just driving it normally without clutching it in RWD. "
Anyway..for the third time...it might be sold.
1st guy got divorced
2nd guy finance fell through
3rd time lucky eh
3rd time lucky eh
Good luck with sale-I'm selling my GTR in Bris and Ive had 4 guys in 2 weeks that the finance has fallen through-mate of mine who in a bank manger said they are dodging loans on GTR's like the plaque. :P
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
