im just after a few personal experiences on the pros and cons of the following ecus, microtech LT or LTX12, ems 8860, wolf 3d v4 plus, new link plus, haltech e8.
will be purchasing one soon to run a rb25det. im not after a plug and play unit as the engine will not using its original loom.
:confused:
thanks for the help
https://www.sau.com.au/forums/topic/80543-engine-management-systems/
:confused:
thanks for the help
Search title ---which ecu ecu ecu
If you intend to use it with RB26 multiple throttle bodies and a MAP only sensor you NEED an ecu capable of throttle angle map maultiple map facility, like Pectel T6 or Motec M800. If using an AFM you can get away with a lesser specced ecu.
