  • Replies 61
Hey Charles after a price on a set of ssr pro's PCD->4 by 114.3 Off set +38 rim size 18" by 8 set of 4 chrome or silver of ya can please charles (Car = Z31 300)
Cheers Mike
here is another addition
Gramlight 57Pro
18x10 +12
suitable for GTR
these have been purchased and on their way shortly.
be the first to jump on this fine set.
$2130
Other sets still available on this and previous page.
  • 1 month later...
  Shane said:
Tom's TN06  SOLD
Although they are sold.
What's the size of the rims pictured?
How much did they sell for?
Do you come across any D-SPEC's to suit 33t as well?
Cheers
Shane
The size or the rims pictured is 18x7.5 and 18x8.5.
they sold for a price not to be repeated. (under $1500)
D-Spec rims can be purchased no probs. :P
Gday mate,
Looking around for some replacement front seats for my '93 R33 GTS-t sedan, keen for some GTR seats or anything else you may have to offer.
Thanks
Matt
  JDMimports said:
(B1),
we have some HKS Hipermax II's for R33 GT-R and
Cusco's to suit S13 on their way. Both sets will be here in a couple weeks.
dont think they will fit on my ecr33. im after some height and damper adj ones in good-great condition with known k's if possible. i was looking at the hyper max on your website. how often do you come across these on yahoo japan auctions?
Hey,
Just wondering what you have available in turbos for direct bolt-on to a r32 GTR - specifically after R34 N1's or HKS 2560's at the moment...
Could you please reply to me with prices if you can get these..
Many Thanks :D
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
