75 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I can't quite see how a mechanical will be any more accurate or quicker to react as long as the electronic gauge has got decent electronics... and things have changed since the 70's in regards to cheap electronics. Afterall, once the signal is converted to voltage, it then drives the needle - rather than the fluid being sent all the way into the cabin. The speed of light is a little faster than the speed of fluid I would think?
In some ways I am not even sure why everything is getting converted to an electrical signal anyhow, and then it uses that voltage to move a silly analogue needle. Especially when a little LCD display is next to nothing these days.
My mate has a mechanical oil pressure gauge .. The fact that the oil is going straight into the cabin is not good at all if you ask me. Always is uncomfortably warm to the touch.
That will be fun in an accident if the oil line gets split and you are stuck in the car with 80+ degree oil spraying you.
Im interested to know... I have an oil pressure guage thats mechanical that plugs into my sandwich adaptor on the block... and there is already oil in it from the sender entrance to the guage... im thinking tho, that the oil in this piece of 2-3m copper tubing will never reach the same temperature as the oil inside the motor... considering its distance from the heat source, the length of cooling it has by the copper piping etc...
JK
oh, trust me, i keep thinking that.. and i have a nasty habbit of fiddling with stuff.. hehe. Its one of those things installed by last owner, that you just really can't be assed pulling out.. but i am sure it would be a good idea.
err :confused: why the hell is this thread up the top again when i posted it yesterday :confused:
With the speed of stepper motors these days it really is of no consequence the speed comparison of the Mech to Elect.. Of course some elect are crap, I prefer Turst guages, but the best are Defi, closely followed by Apexi in my opinion.. I just have a full suite of Trust guages already and refuse to change out as it would cost a few grand for Defi..
Question is: What do you guys prefer?
Electric or Mechanical Gauge?
This is for oil pressure and a boost gauge.
On a side note...
What do the stock gauges use? Mechnical or Electric?
I had a Mechanical Oil gauge mounted in the dash on the passenger side of my S13. My mate twisted it a little. After a long drive he said that he needed a tissue. When he opened the compartment underneth the gauge (here the plumbing & wiring may be found) the whole f@#kin compartment was soaked in oil. The tube connecting the oil supply to the gauge fractured. It was a real bad experience.
So if you ask me I would rather use a electrical gaue because I think they don't have oil lines running to them. Also, I have a mech. boost gauge which I think is not 100% accurate; because on cold mornings when I release the throttle on about 5 vaccum (not sure of the unit for vaccum) I here the flutter. Prior to releasing I here the turbo on boost. They are both autometer gauges.
Both, Go electronic for the Oil, and Mechanical for the Boost.
A good aftermarket oil guage can read off your stock pressure sensor, or will include a replacement that can be fitted in the stock ones location.
The levels of vacume/boost that you are dealing with are pretty small so you arent in any danger of, say, being sucked into the turbo and killed.
The stock boost guage in the dash of a R33gtst is mechanical I think, I tapped into the vacuume line coming up to the bottom of the dash inside the cabin for my A'pexi EL boost guage. responsive wise, when my foot moves on the accellerator, the A'pexi moves instantly. Its miles ahead in responsiveness than the stock dash guage which lags behind.
For example, at idle and looking at the dash instruments when I rev the car. The A'pexi guage responds first, then the tacho flicks up, the oil guage quivers for a second, and lastly, the stock boost guage sluggishly decides to respond.
The drawbacks of mechanical as opposed to electric that I know of is that Mechanical guages might become less trustworthy after a few (3 or 4) years of use and might need to be recalibrated by professionals.
Oh, and lastly. My preference is on a $300 Jap-branded guage which is super responsive over a $130 Autometer. Sure its cheaper, but in my experience they are slow and sluggish to respond, much like the stock guages
In my experience, as a marine fitter, the accuracy of of most gauges is in direct proportion to the quality of the their build and the quality of installation. Cheap quality electronic gauges were a boon in my industry(I've run miles of copper piping) but some are still mech by standards, mainly steam and oil.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
