Just a few pics I took of my car while we were up at mt tamborine today.
I spent 3 hours New Years Eve washing it for my dad's wedding. It was the wedding car!! (Don't have those pics yet.. I will in a few day's and I shall post!)
And yes.. I have new numberplates btw!
Here is another one of the view! Pretty smokey.
And while Andrew sorted out what the noise was coming from the car (it ended up being a tiny stone stuck in our brakes somehow!).... I took photos of the worlds biggest horse... Look how huge it is against a 4 year old kid!
Anyway... While I'm at it. Happy New Year to you all... and I hope you all appreciate the effort I put in to make my car look so shiney :)
https://www.sau.com.au/forums/topic/8058-pretty-pretty-car/
Not a bad looking mo-tor ve-hikle...........What is it????
I see you've joined the 51 club.......congratulations
Hmmm! I see the bonnet is up......looks like your horsepower has escaped ..........how did you get him back in there :D
https://www.sau.com.au/forums/topic/8058-pretty-pretty-car/#findComment-117291
Originally posted by dAVE
nice plates erin :D what happened with the old ones?
jay... i think she was part of the 51 club already with 51nnr.
dave
Andrew's got the 51NNR plates on his laser.. It's turbo. With a big **** off BOV :D MS PSI is bad sometimes because people know its a chick and wont do anything cause they don't want to be beaten by a chick.. even though I'm as slow as a turtle!
Originally posted by SmoothLine
Hey i think i saw you... it was this past weekend yeah?
Did you drive anywhere near paradise point or runaway bay on your way up there? Im sure i saw ya
Erhm... Not that I know of. All day Tuesday I was around Mt Gravatt/Alderley/ Bracken Ridge/Shorncliffe .... that's about it. I haven't been near Runaway bay in ages... sorry
I've got more photos here of the wedding.. I'm just tooo buggered right now to bother scanning them and posting them. I'll do it on the weekend :(
https://www.sau.com.au/forums/topic/8058-pretty-pretty-car/#findComment-117797
I was at tamborine mountain on NYE as well.. checking out all the views from residential areas..
I'm sure as heck that I saw minh in his DR GTR plate yellow r33 gtr just before I started goin up to mountain.. any one confirm this? :)
https://www.sau.com.au/forums/topic/8058-pretty-pretty-car/#findComment-118110
I'm sure as heck that I saw minh in his DR GTR plate yellow r33 gtr just before I started goin up to mountain.. any one confirm this? :D
hahah yeah it was me! :(
You should of pulled me over and said hi. Where abouts were you?
I was staying at my Girlfriends fathers house in Logan Village in STorey St just off North St.
I love that twisty road that takes you out to Logan river Road.
QLD is a gorgeous place. I love Brisbane heaps. Especially Logan Village and Beenleigh area.
https://www.sau.com.au/forums/topic/8058-pretty-pretty-car/#findComment-118475
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
