Hi All,
I'm about to upgrade the front brakes on my R32 GTR and was seeking some advice. I have done a search and read through various other threads on this forum. My car has 18" BBS rims on it and currently runs stock rotors & calipers. It does have braided brake hoses and I use good brake fluid. I'm looking to spend about $1500 including pads. The car is used mainly on the street with occasional track days.
Everywhere I look seems to offer DBA, which I don't really want (I'm unconvinced by them). I would love Porsche GT3, Brembo, AP, or Harrop but all are out of my price range. Any suggestions?
I have looked at Unique Autosports, Racebrakes, DBA, and all the sponsers sites listed on this forum. All only offer DBA below $3000 except the yahoo japan site but I can't read Japanese so it means very little to me.
https://www.sau.com.au/forums/topic/80599-new-brake-advice-for-r32-gtr/
Don't want to rain on your parade, but for the kind of money you are looking at you will only really get new pads & new rotors.
The DBA 4000 series rotors are a good thing. They are slotted, heat treated & marked with thermographic paint. Shop around & try to get a good price.
Unfortunately an upgrade to second hand Brembos will be about $2000 for the hardware.
Let's see if I can convince you............
We have 5 cars in my family fleet, all but one has DBA rotors (it's still under warranty).
We have 7 cars in the race team, all but 2 have DBA rotors. They had to have special rotors machined up using AP Racing blanks. If there was a DBA rotor the same size I would by them, same quality less than 1/2 the price. We use DBA4000's on the road cars and DBA5000's on the race cars. Even after a 20 minute race they can still lock the brakes, which means the tyres are the limiting factor in braking not the brakes themselves.
We have never had a rotor failure, we just wear them out.
On to the other parts of the braking system...............
The main problem I find with R32's is, due to their age, the callipers need servicing, this affects their clamping ability and consistency. For a bit less than $400 you can get a full service, new seals and pistons (if necessary) on the callipers.
Brake pads, there are litteraly thousands of choices. We use Bendix Ultimates on road cars and Hawke carbons (blue compound usually) on the race cars. Plenty of others will have other preferences to suite their individual application and driving style. No matter what brake calliper and rotor you use there will be a choice of brake pads, the more unique the calliper, the smaller the number of choices.
You have already done the brake hose upgrade to braided, which is well worthwhile on R32's due to age. They are similar prices to new rubber hoses from Nissan anyway.
Lastly brake fluid, regardless of the choice of brake fluid it must be changed regularly. Most of the problems I have seen (road and race) are caused by brake fluid past its use by date. We use Castrol SRF, extreme performance, silicon ester based brake fluid with a very high boiling point. When you get the callipers overhauled, start using it from then on as it is best not to mix it.
That will have spent a bit less than your $1500 budget, everything will be as new, and you won't believe the improvement.
Thanks for your responses. I should have added some info...
I currently use Bendix Ultimate pads and recently had the rotors machined and the callipers sercived (about 1100kms ago). The brake fluid was replaced at the same time. I need to replace the front rotors on my white GTR, but figured I'd just swap the rotors from my grey GTR and replace these with larger discs (to fit under the 18" rims). I was intending to continue with the standard callipers, if possible, and only upgrade the rotors.
Every place I go to seems to only sell DBA. I've seen RBA, and Profex (I think) but these were cheaper options to the DBA. Surely there are brands of rotors out there other than DBA for R32 GTR around 330mm for $1500.
unique autosports have a kit from memory is around 800 dollars. it has 324mm rotors and brackets to mount the stock calipers in the right spot.
maybe send them an email or ring them. tell John the beer baron sent you!!
www.nismo.com.au
Thanks Beer Baron.
I have already sent an email to Unique Autosports. Their website claim to have:
STAGE 1 BRAKE UPGRADE KIT FOR SKYLINE R32 GTR
KIT INCLUDES 324MM R33 GTR DBA 4000 SERIES BRAKE ROTORS, CALIPER ADAPTERS, CAP BOLTS AND SHNOOR WASHERS
COMPLETE KIT
PRICE: $795.00 FRONT ONLY,
and
STAGE 2 BRAKE UPGRADE KIT FOR SKYLINE R32 GTR
BOLT ON KIT INCLUDING 330MM SLOTTED & VENTED DISC ROTORS. STANDARD ROTORS ARE 296MM. KIT ALSO INCLUDES ADAPTERS AND HIGH TENSILE CAP BOLTS TO SUIT FACTORY CALIPERS
PRICE: $995.00
My email enquiry was regarding the stage 2 kit- front only?, what brand?, do SAU members get discount?
John responded:
DBA4000 rotors or optional extra alloy hat DBA5000 rotors both heat treated
and slotted. 10% discount SAU
Thanks Beer Baron.
COMPLETE KIT
and
PRICE: $995.00
John responded:
Again I'm only getting DBA as an option.
If you are set against not using DBA then you could source some project mu rotors or some endless rotors. they both make discs in standard 32GTR size.
try www.musecret.com.au and go for the project mu SCR PRO 2 piece rotors. that's what I would get.
You could always get Race Brakes Australia discs (IIRC they sell their own). I think Roy is a big fan of their products.
Out of interest, what do you dislike about the DBAs? They only problem I have ever heard of was one of their rotors fracturing on Targa Tom's car, and the DBA guys were very quick to replace and try and find the cause.
Lucien.
Thanks again Beer Baron.
I've checked out www.musecret.com.au and sent an email to Andrew regarding the SCR PRO two piece rotors you mentioned.
This is what I'm after... CHOICE! I like to consider all options.
I have no personal experience using DBA, I've read reports (mostly +ve, some -ve), and seen images.
Leon from www.musecret.com.au responded that the SCR PRO two-piece rotors for the R32 GTR are $1050 + $70 shipping. I'm getting confirmation on the size. Has anyone used these and able to provide some feedback?
I'm going to look into that, DBA4000, had them on my GTST all the way round. sweeet as and no probs
but I'm going to email and as about stage 1 with DBA 5000's. I've heard they are good. and I wonder if they are any cheaper then MUSECRET ones? made here in aus so maybe
thanks for the info guys!
Whydo you guys want to change calipers, the standard ones are fine unless you have a very quick track car....
Have you checked Sydneykid's suggestions above I'm sure they will give you the braking you need.
im just curious because i've driven about 15 different R32 GTR's this month trying to find my new car and they all seem to have very...'weak' brakes. what i mean is, the cars stop fine, but really need quite a lot of pressure on the pedal. i have just come from driving a 04rex so i'm guessing a more advanced power assisted brake system is whats making the difference?
or all the GTR's i've been driving need new pads and rotors and caliper rebuilds????
dan
well my front brakes were crap when I got them in too, remember you are buy a 10-15 year old car.
Now its got new discs, pads, good fluid, new brake lines and reco calipers it stops brilliant ;) If you still have problems after all that try a new master cylinder.
The GTR brakes are fine when they are working OK ;)
Guest DIRTgarage
dan
For better pedal feel you can bore out a R32 non-abs master cylinder and fit a larger Z32 piston. Then buy the non-abs brake lines from nissan that bolt straight on. Easy!
    • Can't see that being a thing.
    • My fob has never worked, I once attempted to follow the procedure to re-key it, (I have other fobs for the car alarm thing in there). I actually have three of them. Do aftermarket alarms take over the pairing mechanism for central locking? Or do they piggyback off it? I suppose it depends on the system, right? I have four sets of keys/keyfobs. One definitely works, one I think works, one definitely doesn't work, and I have the OEM one that has never worked :p. Is this fixable/workable/whatever? I mean I know it's beyond "just clean it" but how *do* they get synced up?
    • It's actually a really weird comparison... the MX5 is on another level and I kinda question this comparison at all. It'd be closer to compare it to a GTI/Golf/Hatch anything that kicks around. NC MX5 with a turbo has the right to go up with and beat the FD RX7 or 180SX or any other JDM hero car. That's the comparison that would really ruffle feathers.
    • @MBS206 you need more shed in your life... What sort of car is your mates race car?  Hopefully he returns the favour when you're ready to get cracking on yours! None of my mates are into cars so I don't have to worry about that as a distraction thankfully.  I have enough other distractions so I don't need that one too!  Between working 6 days a week (5 1/2 really so 55 hours or so per week), both kids have basketball almost every week night (including Friday night in Melbourne - 2 hours away), my daughter plays netball as well, my sons footy has started now and I coach his under 14's side as well as I'm on the Footy club committee this year, I ride motorbikes every spare Sunday I can find, plus trying to be some sort of a husband.  Life is a busy little exercise at the moment!  I wish there were 8 or 9 days in a week sometimes!
    • Ha ha, that is very true!  I'm too scared to leave it in the position though, it tingles my balls seeing it like that!
