r33 interior full dash steering wheel, airbag both drivers and passenger side manual turbo computer
front shockies and springs $150 for the pair
r33 rear assembly including diff -hubs- axles - RWS unit 500$ im in perth
front headlight passenger side $ 100
aircon unit all the parts minus the gear box and the clutch to do a manaul conversion
let me knwo what you need i may have it all the parts are extras i have from a r33 gtst frontcut
also i have a working rb30 250$
and a rb30 that has done a big end bearing. this motor has a wade stage 3 cam
so i want 250$ for that 2
r33 turbo side feed injectors 250 for all 6
https://www.sau.com.au/forums/topic/80629-r33-parts-perth/
I will find out the airbag stat's over the weekend as the front cut isnt in my backyard
im pretty sure its a 97 gtst but ill have to check
i know the motor had only done 65.000km so it had to be reletivly new
is the top grill bracket broken and do you have a grill
https://www.sau.com.au/forums/topic/80629-r33-parts-perth/#findComment-1466307
u got the the dash panel that goes around the stereo and over to the drivers side vent?
big panel!!!
has to be series 2 though, they boldge out not flat
ill make sure all the pics i can are posted on monday. unable to get to my car untill then :)
I might be Crazy, but once I didnt mind walking.
https://www.sau.com.au/forums/topic/80629-r33-parts-perth/#findComment-1467358
  • 1 month later...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
