  • 6 months later...
  • Replies 82
Hey all,
Just installed my SITC last night. Just wanting to make sure everything is working ok. When I just switch the ignition to on (not start car though) the lights do a little dance and then go Red. Kick the car over then the first one is Green, Second is orange and the last 3 a Red. Is that normal or should they all be green. I used a timing light and tried the 800rpm knob from 10 degrees retard to advance and thats what it showed on the crank when look at it with the light. So i assume that since this knob is working the rest will too.
Thank for any help
Josh
yes that is correct. You should be able to hear the difference in timing at 800rpm going from -15 to +15.
The unit also tracks what revs you are at. For example if you are at 4000 rpm the 4000 rpm light will be green, the 5600 and 2400 will be orange and the rest will be red.
Im a bit gutted it doesnt have an adjustment point for 4600 rpm as thats where the ECU R&R really cuts out.
Yeah sweet. I was only testing it at idle but could hear the revs change when retarding and advancing the 800 knob. And I double checked it with the timing light. Now just have to get it and the safc tuned. I have both units set at zero correction and after fitting the front mount I have raised boost to 10psi and man is it running like sh#t. From about 3000 the ecu is really retarding the timing and then kicks back in again around 4800 to 5000. Light throttle normal driving is ok but when I go wot the map feels like its all over the place not to mention worse fuel economy then I was getting before so I'm assuming I'm hitting R&R. The car has previously made 150awkw with the previous owner but no piggy backs so am hoping for at least that again. However I'm guessing its had a few piggy backs in its life going but the amount of tapped wires on the ecu loom :stupid:
  • 2 months later...
Hi,
Just wondering if anyone can give me an idea of what sort of adjustment settings I should expect to be needing with my S-ITC. I am not planning on doing this myself, car is going on a dyno, but wanted to have an idea to tell the tuner where to start and to compare what he comes up with. I also have a S-AFC neo going in at the same time.
Car:
97 Stagea RS4
Mods are:
*BOS Split front dump pipe
*CATCO Metal Cat
*3" trust exhaust (not sure exactly what one, has two oval mufflers though - from R32 and modded to fit)
*Turbotech mechanical boost controller (These are gated, so actually hold pressure to specified Psi, doesn't just bleed air off constantly. Pretty sweet for $30)
*R34 Skyline Intercooler
*K&N panel filter
*radiator air deflector :D
Planning to be running 9-10Psi boost, depending on what the air temps with just a sidemount cooler look like.
Thanks,
Stu
You'll be fine with 11psi.
I'll get some info on my settings tonight (or try a search on: Tangles SITC settings, Tangles SAFC settings).
edit: here we go http://www.skylinesaustralia.com/forums/in...hl=Tangles+SITC
thanks guys,
looking to get it all done in the next few weeks so will let you know the power figures and settings for comparison. Also have a GTR fuel pump going in, to be on the safe side :(
Where can i get a SITC from? i am having trouble finding it...
here's one for you :w00t:
http://cgi.ebay.com/ebaymotors/JDM-NEW-NEW...sspagenameZWDVW
Just keep an eye on eBay (US site www.ebay.com) as they pop up pretty regularly. 'Used' ones are usually $199. I got mine of this seller in 4 days.
  • 10 months later...
Got my Apexi SITC from Japan though ebay. The instructions are in Japanese but there is a translation somewhere on the internet. If anyone needs it I have the PDF pages for the Stagea. will attempt to attach them but if that doesn't work I can email them.
I would love a copy of these while I can! There are no other alternatives to the S-ITC that I can find (like jaycar iebc / apexi safc are alternatives) so I will probably need to get one of these one day. Can you have a go at posting it here first so we can all benefit, or else PM it to me? Cheers :)
guys try this link:
http://www.ca.dsm.org/tech-sitc.html
do you need me to scan the stagea wire diagram?
its here on the site: http://www.ca.dsm.org/Tech/S-ITC-p.10-11.pdf
*grabbed* awesome, thanks Tangles! Do you know if this suits series 2/R34 as well as series 1?
yeah dowloand the pages for setting up, installing etc, and the stagea / skyline pages
you and/or your mech and his auto electrician will be able to do the job for cheap.
she'll work, she'll work
:rofl:
heads up guys
nother one on ebay US
http://cgi.ebay.com/ebaymotors/Apex-i-Supe...1QQcmdZViewItem
179.95 US
Sh!t, missed it!! thanks for the heads up though
:P
Edited by DaveB
If I've the chance to get a apexi sitc should I go for it??
Car sits as follows, downpipe, decat, hks exhaust, uprated hybrid turbo, uprated fuel pump, apexi airfilter, uprated coil pack, greddy fmic, greddy boost control.
Yes definatley as although they do come up they're still not easy to get. But get a Apexi SAFC while your at it. That way you'll be able to tune Fuel and Timing. Also when you do make changes on the SAFC it can have an effect on the timing also which can be dialed out with the SITC.
Cheers for the fast reply mate! I got one second hand still in box and in good condition ;)
just looking for a well priced safc now! :)
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
