  • Replies 41
Dont forget however that 200rwkw in an s15 6 speed feels a shitload faster than in an r33!
If your thinking about one and dont need the extra space of the Skyline id definatly go for it! Aslong as its not an s14, s14a and s15s are the better looking cars.
https://www.sau.com.au/forums/topic/80647-200sx-question/#findComment-1467304
I'd put it in the 180rwkW region with those mods, at around 1bar.
The injectors and pump won't be maxed out, but they'll be close. For safety's sake you'd get a new pump and injectors before trying to screw out any more power.
The T28 will clear 200rwkW with cams.
https://www.sau.com.au/forums/topic/80647-200sx-question/#findComment-1468623
Aussie S15 T28's all ball bearing? This means with support mods they can hold say 17 psi safely?
I thought the JDM s15s were the ball bearing ones. Like the spec Rs or something. Have a look a nissan silvia they have a heap of dyno threads.
About your question i reckon what everyone else has said around 180- 200rwkw.
https://www.sau.com.au/forums/topic/80647-200sx-question/#findComment-1468695
No, they're not.
I believe the consensus is that the JDM S15s are all BB, but its pot luck as to whether the Australian ones are or not. Silvia owners have compared build dates, VIN numbers, part numbers for the turbo, and there's nothing they can see that differentiates between them.
https://www.sau.com.au/forums/topic/80647-200sx-question/#findComment-1470653
Exhaust housings... as im on NS.com all the time this is where i got that from.
B/B units have a 6 bolt exhaust housing while the non b/b turbos have 4? Maybe 5.
Not 100% sure on the non b/b units but they dont have as many bolts in the exhaust housings, this as well as a slight difference in the part number does show Aus Spec s15s have non b/b units!
https://www.sau.com.au/forums/topic/80647-200sx-question/#findComment-1470660
Well yes, if you look at them you can tell the difference.
But if you're in the market for buying one you won't be able to tell from the build date or VIN number.
From the people I've spoken to on SilNSW and NSCC the part numbers for Au S15 BB and non BB T28s are identical (hence why a VIN number search is fruitless).
https://www.sau.com.au/forums/topic/80647-200sx-question/#findComment-1470691
first of all - which 200sx you talking about?
those mods on an S14 or S14A will get about 180rwkw.
same mods on the S15's tend to get closer to 190rwkw.
my series 1 S14 with 1 bar boost, fmic, SAFC pulled 175rwkw.
ran a lazy 13.8 with heavy 17 inch wheels.
A mate with an S15 and 193rwkw using PFC and 17 psi ran 12.9 on the same night.
on the topic of BB turbo's and shit.
it doesn't mean anything for it to be AUS or JAP spec.
some had Ball Bearing and some didn't.
only way to tell is from the GARRETT part numbers on the stamp which is on a plate on the turbo between the front and rear wheels.
466541 = ball bearing
466543 = bush bearing
the second part of the numbers mean
-001 = S14 turbo (no splitter between wastegate and turbine exit)
-002 = S15 turbo (splitter between wastegate and turbine exit)
https://www.sau.com.au/forums/topic/80647-200sx-question/#findComment-1470738
Scathing -
yeh that would be Brentons right?
I think he had in the region of 225 rwkw with a lot of other mods apart from the turbo.
the original question was using "highish boost"
which doesn't mean much really.
So to "me", the stock setup runing 7psi of boost, "highish" would be double and a little more..
so I'd say that 17psi is highish for a stock turbo.
The example I gave of my mate that ran the 12.9 was using 17.5 psi boost on his stock S15 turbo.
Scathing, if you are the same scathing on other forums, then you'll know Dale.
and I think that night you were hitting 14 flat in the tree fiddy... if that is you..
his other mods at the time were.
stock dump, then 3 inch back.
hyperflow intercooler with silicon hosing.
AVCR
GFB hybrid bov
17x7.5 rims with Dunlop DJ-01's
Power FC
stock clutch
stock pump
stock injectors
stock fuel pressure.
stock turbo... etc
I don't think the difference between the BB and non BB is not so much power but the driveability.
I would "ASSUME" that the BB turbo would build boost at a faster rate.
I guess they have other bonuses like higher tolerances to extra boost maybe but I can't say from experience.
https://www.sau.com.au/forums/topic/80647-200sx-question/#findComment-1472208
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
