Garage Cleanout - Random Stuff Fs
Note: Stuff that i'll take as a trade :
slotted rotors (r33 gtst) in good condition
cheap sub and amp
lilliput touchscreen 7" monitor
More New Stuff added:
Item 1 - bottle of motul gear 300 synthetic gearbox oil. Bought too many. They're $39 at autobarn now. Give me a decent offer and it's yours.
Item 12 –Pivot super temperature controller. This is a full temperature monitoring/controlling unit. It can be used to monitor stock sensors as well as aftermarket sensors. Comes with a temp probe. You can hook it up to the stock water temp sensors monitor your water temperature and use the probe to measure oil temperature. It also has output for doing things at temperatures you set. This is a digital unit so you don’t’ need to have 2 ugly gay gauges on your dash. BRAND NEW. Unwanted present. $300.
Item 13 - 7.2cm x 10m of self-adhesive insulation tape. Good for keeping intercooler pipes cool. Excellent if your pipes are looking rusted and old. Brand new. $40
Item 14 – splitfire gauge cup/gauge ring. 2 5/8”. It can either be used with the anondised blue cup, or you can just use the ring to hold the gauge. Looks really nice. Includes all screws and brackets. Brand new and never opened. Unwanted present. $20.
Item 16 - ½” torque wrench. Brand new. Cheap. $20.
Item 3 - sII rb25 turbo. Minimal shaft play consistent with low km turbos - $450.
Item 5 - rb25 and vg housings http://www.skylinesaustralia.com/forums/in...=164956&hl=
Item 7 - rb20 copmressor elbow - $30
Item 8 - Random turbo install parts - wastegate actuator. turbo dump studs, oil drains, oil drain gaskets, copper washers - just pm me
Item 9 - Assorted Strut braces. Brand New. These are very nice and stiff. Once I installed one onto my car, I could stand on it, and it wouldn't really flex. I have a 300zx brace, rx7 brace and a supra brace. Price: $80 each
Item 10 – Brand New 225/50/r16 tyres. These are Hercules 3000v. This is not a common brand in Australia, but this is their top of the range tyre. Tyres have rim protectors. Come and have a look at them and squeeze/feel the rubber. They are very soft and grip very well. I’m currently using some on my car atm. They are one of the best tyres I have ever used. I’m looking for 125 each. This is really cheap considering even nangkangs (shittest tyres in the world) in this size at Tempe tyres are $125 each. At this price, you’re getting good rubber, you can’t buy anything brand new like this at that price. Seriously, just feel them. :(
Item 11 – NTK AU Falcon O2 sensor. Used for approximately 1000ks for some testing. $100
PS: Guys, keep in mind that some of the above prices are negotiable to some extent. Don't like the price? make me an offer.
Pickup from Sydney, postage at buyer's expense.
I can be contacted on 0403 211 482 - Chris
Item 6 - big workshop trolley jack
Item 2 - cheap 17" semis SOLD
Item - 205 50 r16 RE55 semi slicks SOLD
Item 15 - Pedals. Nice. Brand New. Unwanted present. SOLD
Item 4 - rb25 turbo elbow SOLD
Item 1 - aerospeed cam gear SOLD
Item 1 - GTR Fuel pump. SOLD Thanks ben|1981
Item 1 - GTR Bov. SOLD Thanks Stealth
Item 15 - Nice phone for cheap SOLD Thanks will-32
Item 3 – A pair (2) PIAA five spoke wheels. SOLD. Thanks DNR33
Item 6 – Greddy Oil adapter plate. SOLD. Thanks lineski 33
Item 1 – r34 GTT Turbo. SOLD. Thanks GTShortie
Item 15 - Brake bleeder. SOLD. Thanks Malteser
Item 5 - Stock r33 GTS-T wheels. SOLD Thanks Guilttoy
Item 8 – r32 front Strut Brace. SOLD. Thanks RaceBNR
Item 4 - Ford falcon AU coil pack unit and leads. SOLD. Thanks daemon667.
Item 9 - Catch can. SOLD. Thanks markk
Item 10 - High temp hosing SOLD. Thanks markk
Edited by MANWHORE
  • Replies 56
  • 4 months later...
  • 7.2cm x 10m of self-adhesive insulation tape. Good for keeping intercooler pipes cool. Excellent if your pipes are looking rusted and old. Brand new and never used. Reason for sale is I bought two rolls to do my car, but I only needed one.$40
  • Anondised blue gauge cup. 1 5/8”. Includes all screws and brackets. Brand new and never opened. Unwanted present. $20.
  • Torque wrench. Brand is unknown. ½” socket type. It is the flex bar type, not the spring type (supposedly more accurate than the spring type). Never used before. Cheap. $20.
  • Brake bleeder. Consists of a clip on hose with one-way valve. You no longer need one person to press the pedal and one person to open the bleed nipple. Just attach this and open the nozzle, and press the pedal yourself. Easy. This has never been used, as it was an unwanted present. Save yourself lots of money bleeding your brakes yourself. $15.
  • Spring Compressors. Standard. Used a couple times. $20
  • 4x stock commodore steel wheels 15". Good for burnout/drift rims. 5stud. I believe it is a different stud pattern to nissan though. perfect if you have a commo- make an offer - beer, whatever.
Everything is located in Sydney on the North Shore
  • 1 month later...
  • 5 months later...
 Share
    • Hi all,   I have been a member here for years and am back to owning an R35.  It's my car and thought members of the community might enjoy sharing my journey.  I am definitely here to join the conversation.  If sharing this content isn't appropriate or it belongs somewhere else, I am happy to have it deleted or moved...
    • Data looks rock solid? I'm assuming you jabbed the throttle twice OR once? the TPS voltage moves up and down twice, however you've mentioned you did it once.
    • Having not watched the videos, I'm unsure, but this may be better suited to the importing thread?
    • Update on this situation: (Forgot to put in my previous post that I bought another brand new pressure gauge and fuel shows the same 50psi) I've deleted all the aftermarket immobilizers and turbo timer shyt and placed all factory wiring back to normal. The problem is still the same and nothing changed, but atleast it's a bit more tidier under the steering wheel. I've also siphoned out all the old fuel and then poured new batch of BP98 fuel (about 15L) into the tank. Nothing changed. Still the same idle. I also changed out the MAP vac line with a new one and, still the same.  So 2 days ago, I thought fk it. I'll just change out the fuel rail and injectors with another set that I know worked well in my brother's R34 a while back. That other fuel rail has the exact same Xspurt 640cc as what I have right now. So I changed it out to that other fuel rail and injectors (new O-rings) and injector harness. Put everything back together, started the engine, 464906286_1624569924763105_5179888796065901094_n.mp4   and yeah... still the same 50psi and idle problem. 🫠 I can also hear each of injector's solenoids running when I put a screw driver to it and have the other end to my ear. I might get a noid light just to confirm pulsasion but yeah, very strange that both fuel rails and injectors put out 50psi.  31-10-2024.csv I've attached it here. I started recording, then started the engine and let it idle with no throttle, then at the end I applied a little throttle and then stopped recording.    So, now idk. I'm going to see if swapping out the brand new R35 coils to my old splits fires will change anything. 🤷‍♂️
    • Hey mate, nice work on the car. Just a quick note, people generally don't like it when you use the forums to dump and run to advertise your YouTube content. If you're gonna stick around and join in the conversation then great, but if not this might not be the best place for you.
