Note: Stuff that i'll take as a trade :
slotted rotors (r33 gtst) in good condition
cheap sub and amp
lilliput touchscreen 7" monitor
More New Stuff added:
Item 1 - bottle of motul gear 300 synthetic gearbox oil. Bought too many. They're $39 at autobarn now. Give me a decent offer and it's yours.
Item 12 –Pivot super temperature controller. This is a full temperature monitoring/controlling unit. It can be used to monitor stock sensors as well as aftermarket sensors. Comes with a temp probe. You can hook it up to the stock water temp sensors monitor your water temperature and use the probe to measure oil temperature. It also has output for doing things at temperatures you set. This is a digital unit so you don’t’ need to have 2 ugly gay gauges on your dash. BRAND NEW. Unwanted present. $300.
Item 13 - 7.2cm x 10m of self-adhesive insulation tape. Good for keeping intercooler pipes cool. Excellent if your pipes are looking rusted and old. Brand new. $40
Item 14 – splitfire gauge cup/gauge ring. 2 5/8”. It can either be used with the anondised blue cup, or you can just use the ring to hold the gauge. Looks really nice. Includes all screws and brackets. Brand new and never opened. Unwanted present. $20.
Item 16 - ½” torque wrench. Brand new. Cheap. $20.
Item 3 - sII rb25 turbo. Minimal shaft play consistent with low km turbos - $450.
Item 5 - rb25 and vg housings http://www.skylinesaustralia.com/forums/in...=164956&hl=
Item 7 - rb20 copmressor elbow - $30
Item 8 - Random turbo install parts - wastegate actuator. turbo dump studs, oil drains, oil drain gaskets, copper washers - just pm me
Item 9 - Assorted Strut braces. Brand New. These are very nice and stiff. Once I installed one onto my car, I could stand on it, and it wouldn't really flex. I have a 300zx brace, rx7 brace and a supra brace. Price: $80 each
Item 10 – Brand New 225/50/r16 tyres. These are Hercules 3000v. This is not a common brand in Australia, but this is their top of the range tyre. Tyres have rim protectors. Come and have a look at them and squeeze/feel the rubber. They are very soft and grip very well. I’m currently using some on my car atm. They are one of the best tyres I have ever used. I’m looking for 125 each. This is really cheap considering even nangkangs (shittest tyres in the world) in this size at Tempe tyres are $125 each. At this price, you’re getting good rubber, you can’t buy anything brand new like this at that price. Seriously, just feel them. :(
Item 11 – NTK AU Falcon O2 sensor. Used for approximately 1000ks for some testing. $100
PS: Guys, keep in mind that some of the above prices are negotiable to some extent. Don't like the price? make me an offer.
Pickup from Sydney, postage at buyer's expense.
I can be contacted on 0403 211 482 - Chris
Item 6 - big workshop trolley jack
Item 2 - cheap 17" semis SOLD
Item - 205 50 r16 RE55 semi slicks SOLD
Item 15 - Pedals. Nice. Brand New. Unwanted present. SOLD
Item 4 - rb25 turbo elbow SOLD
Item 1 - aerospeed cam gear SOLD
Item 1 - GTR Fuel pump. SOLD Thanks ben|1981
Item 1 - GTR Bov. SOLD Thanks Stealth
Item 15 - Nice phone for cheap SOLD Thanks will-32
Item 3 – A pair (2) PIAA five spoke wheels. SOLD. Thanks DNR33
Item 6 – Greddy Oil adapter plate. SOLD. Thanks lineski 33
Item 1 – r34 GTT Turbo. SOLD. Thanks GTShortie
Item 15 - Brake bleeder. SOLD. Thanks Malteser
Item 5 - Stock r33 GTS-T wheels. SOLD Thanks Guilttoy
Item 8 – r32 front Strut Brace. SOLD. Thanks RaceBNR
Item 4 - Ford falcon AU coil pack unit and leads. SOLD. Thanks daemon667.
Item 9 - Catch can. SOLD. Thanks markk
Item 10 - High temp hosing SOLD. Thanks markk
Edited by MANWHORE
https://www.sau.com.au/forums/topic/80672-garage-cleanout-random-stuff-fs/
  • Replies 56
  • 4 months later...
  • 7.2cm x 10m of self-adhesive insulation tape. Good for keeping intercooler pipes cool. Excellent if your pipes are looking rusted and old. Brand new and never used. Reason for sale is I bought two rolls to do my car, but I only needed one.$40
  • Anondised blue gauge cup. 1 5/8”. Includes all screws and brackets. Brand new and never opened. Unwanted present. $20.
  • Torque wrench. Brand is unknown. ½” socket type. It is the flex bar type, not the spring type (supposedly more accurate than the spring type). Never used before. Cheap. $20.
  • Brake bleeder. Consists of a clip on hose with one-way valve. You no longer need one person to press the pedal and one person to open the bleed nipple. Just attach this and open the nozzle, and press the pedal yourself. Easy. This has never been used, as it was an unwanted present. Save yourself lots of money bleeding your brakes yourself. $15.
  • Spring Compressors. Standard. Used a couple times. $20
  • 4x stock commodore steel wheels 15". Good for burnout/drift rims. 5stud. I believe it is a different stud pattern to nissan though. perfect if you have a commo- make an offer - beer, whatever.
Everything is located in Sydney on the North Shore
  • 1 month later...
  • 5 months later...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
