long story short... Whist washing car ready for the show and shine.. Cleaning the engine bay with degreeser... few hrs later..pour water over the engine to get rid of stuff (friend who helped me wash car did this).... Driving home on the M4 car wouldnt go over 3000RPM., very scarey... it was going soo slow...
Another few hours later...
Opened up the coils and found the 1st one to be ok (no water), however 2nd one had about 3cms of water. Got most of it out. The other 4 havent been opened.
Now what should I do?
1. Leave it in my garage for 1week and dont drive it. Hopefully let it evapourate?
2. Take it to a mechanic BD4's in gladsville get them to look at it.
3. Try and fix it myself. Which is hard coz its very hard to gain access to the coils due to the throtle thingy.
4. Something else?
*sigh* any advice would be great.!
Im so sad now :(
https://www.sau.com.au/forums/topic/80677-water-in-coils-of-engine/
leaving water in there will cause the spark plugs to corode and they will very quickly.
Mine did the same thing after i washed my pod filter and subsequently it stuffed the air flow metre which caused the not going over 3000rpm in my car.
Also take the nipples off the bottom of the coil packs and dry the inside of them out aswell as making sure the spring or carbon is dry and clean off dirt.
take coil packs out. Wipe everything down to get rid of excess water. Grab your gfs/wife/mums hair dryer to dry anything else up, or to dry out the coils. Not too close though that you burn anything or burn out the hairdryer.
Just an idea. Though with the driving you should have got rid of most of the water I would think..
hmm this may sound like a hassle but I dont have any of the tools...
Dont suppose anyone can come over now and help me out? or even Monday?
I dont have the courage to do it myself.
If not then id have to take it to BD4s and get it fixed.
And spray the springs and contact points of the coils with WD40...
When I had moisture corrode the contact points in my coils I had the same thing, it would splutter over 3000rpm. After cleaning them up, went back to normal.
of course water...!
When we opened up the 1st two coils yea saw water in the 2nd coil.
We couldnt access the other ones, so i took it to mechanic, also the fact that I dont have time to tinker with it.
Its all good now. Runs same or better than before... :P
Though now my rocket cover is cut in half :D Wanna get carbon fibre ones lol. anyone know where? :D
f--k. Talk about a funny thing to do. You cut the piece that has Nissan 2500 twin cam etc written on it right?
You don't need this. On series 1 an ignitor module sits on it at the back that you would need to secure to something else (I cable tied mine around the brake lines to ABS module..its not heavy at all).
Just curious - what did you use to cut it? I would think that would be fairly hard to cut while in position there. A lot harder than removing the crossover pipe etc.
Thats funny...
BTW it keeps the coils cooler if you leave this cover off (i.e. the one you cut up) and you can change spark plugs easier. Not sure if a bit more heat may go into the intake crossover pipe - but I think it would be marginal.
