What are the differences?
from HPI #51, "RB26 Evolution"
Unbeknownst to most is the differences between R32 and R33 GT-R turbochargers. There are differences no so much in the exterior housings, but in the compressor wheels and in turn the dump pipes, which allow a stock-turbo R33 with bolt-on mods to make significantly more power than its R32 equivalent.
Both of these versions carry the handicap of ceramin turbine wheels though. Whereas 1.2-1.3bar of boost pressure on the R34 turbochargers is a 'gimme', the wise tuner keeps the boost under 1.1bar on the early models and leaves it at that.
It seems that no-one actually knows specifics...
but I hope this helps a little
do not run 1.2 to 1.3 on r34 turbos they go bang to, trust me i know
yeah say bye bye to ceramin no matter what model R it is , it will save you money in the end
I think it will be fine to use R32 and R33 GTR turbos together. If there are any differences in compressor wheels they would be very minor. I'm still unconvinced though that there are any differences at all. The "GT-R Owners Book" I bought from Japan shows the difference between all factory turbos. From the specs listed there is NO difference. Yes the dumps are different though.
That particular article in HPI #51 has so many errors in it. Almost all of the information about the R34 motor is completely wrong. Other articles lately have had wrong information too. Unfortunately, you can't believe everything that you read in a magazine.
Gary could you please elaborate on your post? :confused: I have little love for HPI on the whole, and would love to have the story set straight.
Did you respray it after you imported it or sumthing?
Without making disparaging comments about import brokers, suffice to say the description of the car was missing quite a few important (and obvious) details. I don't mind sharing, so if you are interested in hearing more, beam over a PM :P
Well here are a few things they said about the R34:
1. "R34 turbos are a spitting image of an R33 GTR N1 turbo" - WRONG
They are completely different. Different housings and different wheels.
2. "R34 GTR cams have alterted duration and lift" - WRONG
The cam duration and lift are the same for all GTR's. The difference in the R34 cams is the "lobe centre angle" (cam timing). Basically the R34 cams are like having R32/33 cams with cam gears set at 4 deg advanced intake and 4 deg retarded exhaust.
3. "R34 cams won't fit in an R32/33 head" - WRONG
They sure do. There are many people that have done it. The difference is in the connection to the crank angle sensor. The R34 CAS will not fit into R32/33 cams or vise versa.
4. "R34's have a completely recast head"
I don't think so. There may be some minor changes though. I know SK said they have different squish zones. Maybe someone who has properly compared the two can say.
5. "R34 blocks have extra ribbing like N1 blocks to avoid cracking"
My understanding is that N1 blocks are actually made from a different material to provide the extra strength. I have a photo with a comparison of the standard block (05U), N1 block (24U) and the Group A block. It's very hard to see any differences. If only I could read japanese better, then I would know. I'd like to see where the extra ribbing is that they talk about. As for the R34 block they are still stamped with 05U and I don't think they are any different. Plus my tuner has seen them crack before. Again if someone has compared the two properly I'd like to know.
It's just annoying when rumours spread and then end up in magazines.
Gary,
Does that GT-R handbook list the stats for the R34 N1 GT-R turbo? If it does, and you don't mind, can you post up all the dimensions? Just trying to compare to other options as per this thread: http://www.skylinesaustralia.com/forums/sh...ead.php?t=80624
Cheers,
Lucien.
I have a photo with a comparison of the standard block (05U), N1 block (24U) and the Group A block. As for the R34 block they are still stamped with 05U and I don't think they are any different.
Only saying wat i read...
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
