Hello everyone,
I might be new here but not elsewhere. My Boss's Skyline has died. He's rebuilding the top end himself and paying an engine shop to do the rest.
How ever here is where I need some help.
We can't find any workshop manuals for R33 Skylines. If we go to Nissan the manual will cost around $360.
So I was wondering if anyone knows what the torque specs are for the head and other top end components.
Edited by RTA 13B
https://www.sau.com.au/forums/topic/80718-torqueing-specs-for-r33/
I found the manual thread, with all the uploads for nearly all the skylines.
Three problems;
1)My printer keeps printing code only
2)My internet speed is down I just finished doing my tax return on line and it sucked up our internet download space.
3)I have tried the links but none of them worked.
As both my boss and I are mechanics, (we work in heavy vehicles, so are torque range is usually above 300nm) we need to know just torque specs for the head bolts and fly wheel bolts.
Help will be much appreciated.
  • 10 months later...
Okay this is embarressing.
I need the torque specs for RB25 DET head bolts.
eg:
tension torque sequences
1st tension
2nd tension
3rd tension.
We've had to pull the head off again.
And r33GTS-t-200kw link isn't showing anymore.
yeah much appreciated, thanks.
eg:
1st tension
2nd tension
3rd tension.
Tighten to 29 nm , second step 98nm, then loosen them all.
Tighten to 25-34 nm, then 95-10 degrees, or93-103nm
  • 4 weeks later...
does anyone know the tension for the conrods?
rb25det
im replacing my rods for rb26 rods
whats the tension for standard and also rb26 if they are different
thanks!!!
Tighten 14-16 nm then turn 60-65 degrees, make sure you oil the nut and the surface.
To save you asking again mains are 46-52 nm , again oil the thread and the friction surface .
