* DUE TO CONFLICTING OPINIONS, THIS MAY OR MAY NOT WORK. IT HAS FOR SOME, HASN'T FOR OTHERS*
This came up a while ago and I have had the same problem since I imported the car 6 months ago.
Basically when cold the car won't idle up on its own, you need to stab the throttle then its fine. When its warm its not a problem.
I went through the whole lot, cleaned throttle body, AAC, air regulator, Plugs, packs the works.
Today I bought a new battery as my old one was shagged, the new one is a Bosch Silver series, pretty bloody big, just fits on the battery tray and had to make up new terminals and such. Cost $99 on special so not a cheap one.
Result? Car fired up straight away and idled up perfectly! No throttle needed and it turned over in half the time it normally takes. I have'nt driven it for a week either so this was certainly the test.
It seems the ECU needs max volts to operate the cold start properly. The previous battery in there was about half the size of the new one, its a brute!
Definately worth the 100 bucks as I think many cars, especially with most of us running fairly serious stereo gear can benefit from the biggest battery we can fit in the space available.
Good luck!
https://www.sau.com.au/forums/topic/80731-cold-start-problem-r3233-owners-read/
Are you positively annoyed friend? dude mate, sounds like u got the fix to my problem.
I will be grabbing a battery on Monday and trying this.
As my battery neally dead too, and need to keep the stereo going like u say.
i will let ya know teh outcome !
See ya mate.
Hey my car has the same issue, never thought of it as a problem though, just a little quirk.
Maybe ill get a bigger battery next time.
Thanks for going to the effort of doing the research.
I've got the same problem.
I suspect its my injectors. I've replaced battery's etc.. no difference, does spin over quicker though.
Mine doesn't always do it but most of the time it does. Within the pfc controller if I richen up the water temp compensation for cold start the idle stumble goes away.
So mine appears to be fuel related.
You think wrong. hehe :rofl:
On the stock ecu, mine stumbled and spluttered exactly the same. Exactly.
The only way I have been able to get rid of it is to richen up the water temp fuel compensation tables once I got the PFC.
I've heard other R32's with stock ecu's stumble splutter, I've also heard other PFC equiped R32's stumble splutter then a stab of the accelerator brings her to live.
It appears to be something other than the ecu, battery etc. I think it is fuel related. Remember mine didn't 'always' do it but 90% of the time. Once it even went a few months starting perfectly then it went back to its usual splutter.
Maybe its an earth issue, playing with the battery has temporarily fixed it. :P
I'll update as I go but it started perfectly this morning :rofl:
Someone else a while ago suggested it as well as a new battery fixed his.....
Maybe the stock battery terminals are stuffed? I changed mine to huge gold plated ones.
Either way, its worked for me so far so if its goes back to its old ways i'll be back ,:P
i have the exact same problem on mine.
battery died last week so i replaced the battery, but didnt do anything
i havent bothered to look into it further, its been like this since i got the car 2 years ago.
i wish i could fix it though coz my remote ignition is useless
hmmm bizzare.
All I know is it works for me so I'm stoked :D
Maybe Nissan will hold the answers?
Did you replace it with a bigger battery? Maybe the batterys are undersized in them?
Who knows, did'nt hurt though cause my battery needed replacing badly. WOuldn't hold charge for more then a day.
Well i went out on my day off and shopped for batteries, but ended up at super cheap wiht a Bosch Gold Series one, cos me 89, ten Bucks off.
Thing is tho it was taller, lil, well the Terminals are form the top, not sunken in like the stock batt. The Wires with teh battery terms. were too short. arrrgg
so i used some big arse amp white and attached to the old bat climps and then attached new ones to the ends of amp wire, seems to go fine, haven't had teh moring test yet, that is tomorrow.
I got to find better way to joint that big arse wire so i 100% sure i getting percet connection.
If got any ideas on the joining let us know.
Anyway i let ya's know how all goes.
Later,
haha Thats bodgy as sh*t. :D
Head down to supercheap or where ever and grab a nice new big fat earth wire.
Thats one fixed.. Unsure what to do about the other one though. :D
I replaced it with a 480cc Excide thing with a nice little window to see the condition of the battery. It spins the car over rather quick.
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
