Hey people,
i was woundering what sort of coldair intake setups are people using on the skyline specifically R33 Gtst. Any sugestions and prices or pics would be appreciated.
cheers
I have a front mounted intercooler opposed to the original side mount. When you take the stock intercooler out, the piping going to the intake can be routed a different way, leaving a hole.
I cable tied 90mm PVC piping (90 degree bend) under this hole, so the air gets fed from the corner of my 400r bar.
I also use a UAS cold air box, with that shiney insulation stuff lined on the whole inside of the box.
Mine works a treat :)
Sorry, no pics.. Might grab some next time front bar gets taken off
https://www.sau.com.au/forums/topic/80745-cold-air-intakes/#findComment-1467732
i have also replaced the standard intercooler with a gtr cooler up front
i relocated my pod down into that space
awesome in dry conditions
in the wet, i just take it super ez to try and minimise the chances of sucking up water
https://www.sau.com.au/forums/topic/80745-cold-air-intakes/#findComment-1467762
The only other way you could do it is setup a box around the pod and make up sum sort of duct to extract the air coming in from around the headlight. It sounds silly but apparently works quite well. 'SS Inductions' i think it is sells a setup like that.
https://www.sau.com.au/forums/topic/80745-cold-air-intakes/#findComment-1467969
Infact now that i think of it you could use the stock air pick up ducted to a box made up for the pod. That pick up sits up above the headlight and sucks air between the bonnet and headlight. Not sure if you'd still have it there or ever did?
https://www.sau.com.au/forums/topic/80745-cold-air-intakes/#findComment-1467971
Al_r33 i've got the blitz one your talking about. It works realy well. On boiling hot days the output side of the intercooler is always freeeezing for ages after you turn off the car.
On thing about that intercooler though is the intake pipe that goes into the intercooler sits 1cm or so lower than the front bumper, so you goto go extra slow over the bumps etc.
https://www.sau.com.au/forums/topic/80745-cold-air-intakes/#findComment-1467973
how much did that cost you? im planning on incorporating a cold air intake with a new intercooler later down the track, as i recently bought the car, and its just got an exposed pod in the engine bay. Tho im thinking of going gtr intercooler as that would be pretty much bolt on i assume
https://www.sau.com.au/forums/topic/80745-cold-air-intakes/#findComment-1468055
i think there about $1500 or so. I got mine for $1200 during xmas sale. Was abit expensive but i wanted to test out the credit card.
I think with the gtr cooler you'd need custom pipes to hook it up.
The blitz one uses the stock pipes in the engine bay, whereas the gtr one is like most intercoolers and has the pipes going left and right.
I do prefer the look of the normal/gtr intercooler over mine though :)
https://www.sau.com.au/forums/topic/80745-cold-air-intakes/#findComment-1468065
On my VS commie amd my S5 t Rx7 I had my pod filters behind the front bar.
In the wet I leave the front of it covered by a plastic bag. (sounds dodgy, but if it's your daily there's not much choice.)
If only the front is covered then it can still suck air from the sides. Also don't drive too close behind others as you will still suck up all of there spray.
https://www.sau.com.au/forums/topic/80745-cold-air-intakes/#findComment-1469023
When i installed the intercooler I was only running stock 5-7psi boost. So I wasnt realy expecting that much of a differance. There was a small differance in the power but as well as some added lag :D . I was kinda more impressed with the cool wooshing noises it was making though :)
That same day we put the 3" exhaust on and that made a big differance to power which I could feel straight away.
I rekon I would of got the same results above with most intercoolers though so its hard to say.
All I know is it goes incredibly cold real quick and lets me run more boost :(
https://www.sau.com.au/forums/topic/80745-cold-air-intakes/#findComment-1469460
this is the cold air intake I have on my R33, it has a snorkle running the cold air up under the KN pod. also I have put a wanky blue light in the air box so when the bonnet opens the light comes on and shines through the smoked glass slot. I hope it will keep the intake temps down from the new turbo!
https://www.sau.com.au/forums/topic/80745-cold-air-intakes/#findComment-1470584
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
