Hi guys, I am new here and have read, and read hundreds of posts to answer my question but am having trouble finding a solid answer.
I have a 93 R33 GTS-T and have blown the turbo. I am wondering what are the cheapest and easiest options for a simple bolt on replacement ??
What different brands offer direct bolt-on replacements ???
Any help you guys can offer will be much appreciated as I am a total newbie to turbos and I have limited funds to replace the blown one. Thanks Trev....
https://www.sau.com.au/forums/topic/80758-direct-bolt-on-replacement-for-rb25/
If you have limited funds the best bet would be to get the blown turbo reconditioned and high flowed. After getting the turbo high flowed is usuallyg ood for 400hp or so.
Usually costs around 1500.
www.gcg.com.au
Or if you want to spend more money there are heaps of aftermarket items from HKS, TRUST etc etc.
www.nengun.com have some good prices.
Hope this helps
Or are they even any direct bolt on replacements ?? Sorry if these questions are common knowledge but I read for a few hours trying to find a direct replacement with no luck. I have been looking at a few for sale on an auction site but am worried they aren't as they say direct bolt on. I have been told I need to change oil lines and exhaust or something like that. Please guys any help you can offer would be a huge help. Otherwise I have to get this one rebuilt. Again Thanks all for your time and help on this. Have a good week... Trev
buy another stock one .. bolt that back on and keep driving ..and save up some cash to have your blown one rebuild.
few for sale at the moment in the for sale section .. 350 - 450 bucks..
Matt
Thanks for that Matt. Is the stock turbo going to be the only turbo that I can bolt on with no other mods needed ?? The money isnt really an issue anymore because I'd rather upgrade it to a better turbo now than buy a stock one and then spend more money in the future upgrading that one..... Thanks again for everyones help on this..... Cheers Trev...
it'll bolt straight back in.
use it for a little while ..get your blown one hi flowed.. fit that back up ..that'll bolt up all the same as before ..then sell the stock one u used in the mean time.
i mean its up to you really..... GCG is in your area ..well i think they sydney based anyways.. and its about a 4 day turn around or something depending on work load.
most other bolt on turbos will require different oil and water lines.. but u usually buy them as a "bolt on kit" with everything u need to bolt on ..... if u want bolt on ..buy a FULL kit. not just the turbo ....saves u running around that way.
all the best buddy
Matt
Also, a bigger turbo, such as a hiflow GCG or HKS, etc., require the support systems.
Such as: Programmable ECU, Larger injectors, Larger fuel pump, 3in turbo back exhaust, FMIC, etc. If you do not have these fitted and do not want to spend BIG dollars to get them done, i suggest you buy another second hand std turbo.
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
