Hi guys, I am new here and have read, and read hundreds of posts to answer my question but am having trouble finding a solid answer.
I have a 93 R33 GTS-T and have blown the turbo. I am wondering what are the cheapest and easiest options for a simple bolt on replacement ??
What different brands offer direct bolt-on replacements ???
Any help you guys can offer will be much appreciated as I am a total newbie to turbos and I have limited funds to replace the blown one. Thanks Trev....
https://www.sau.com.au/forums/topic/80758-direct-bolt-on-replacement-for-rb25/
If you have limited funds the best bet would be to get the blown turbo reconditioned and high flowed. After getting the turbo high flowed is usuallyg ood for 400hp or so.
Usually costs around 1500.
www.gcg.com.au
Or if you want to spend more money there are heaps of aftermarket items from HKS, TRUST etc etc.
www.nengun.com have some good prices.
Hope this helps
Or are they even any direct bolt on replacements ?? Sorry if these questions are common knowledge but I read for a few hours trying to find a direct replacement with no luck. I have been looking at a few for sale on an auction site but am worried they aren't as they say direct bolt on. I have been told I need to change oil lines and exhaust or something like that. Please guys any help you can offer would be a huge help. Otherwise I have to get this one rebuilt. Again Thanks all for your time and help on this. Have a good week... Trev
buy another stock one .. bolt that back on and keep driving ..and save up some cash to have your blown one rebuild.
few for sale at the moment in the for sale section .. 350 - 450 bucks..
Matt
Thanks for that Matt. Is the stock turbo going to be the only turbo that I can bolt on with no other mods needed ?? The money isnt really an issue anymore because I'd rather upgrade it to a better turbo now than buy a stock one and then spend more money in the future upgrading that one..... Thanks again for everyones help on this..... Cheers Trev...
it'll bolt straight back in.
use it for a little while ..get your blown one hi flowed.. fit that back up ..that'll bolt up all the same as before ..then sell the stock one u used in the mean time.
i mean its up to you really..... GCG is in your area ..well i think they sydney based anyways.. and its about a 4 day turn around or something depending on work load.
most other bolt on turbos will require different oil and water lines.. but u usually buy them as a "bolt on kit" with everything u need to bolt on ..... if u want bolt on ..buy a FULL kit. not just the turbo ....saves u running around that way.
all the best buddy
Matt
Also, a bigger turbo, such as a hiflow GCG or HKS, etc., require the support systems.
Such as: Programmable ECU, Larger injectors, Larger fuel pump, 3in turbo back exhaust, FMIC, etc. If you do not have these fitted and do not want to spend BIG dollars to get them done, i suggest you buy another second hand std turbo.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
