Changing the fuel pressure WILL NOT alter the duty cycle (although it will alter the REQUIRED duty cycle, but you have to change that). All it will alter is the amount of fuel that gets injected during the "injector open" period.
If you back off the base pressure, then you will effectively lean off the mixture. If you increase the pressure, you will richen the mixture.
The copious quantities of black coming from the exhaust suggest you need to reduce the pressure a bit.
OMG....talk about people making things difficult with all this consult bullshit and guessing ect..........heres what you do....underneath the steering column theres a small trap door....open this and you will see a connector....Here is a dodgy pic i took from the R34 GTR factory schematic book.....if you momentary earth out he test wire the vehicle will enter diagnosis mode....the engine check light on the dash will give you a series of flashes....eg on once then on four times is code 14....once you have done a decode post up the code and i will tell you what it means.....on 34 GTR's you can also switch the dash meter into a sensor diagnosis mode...you do this by holding the two outside buttons down while turning the ignition switch on.....then when the GTR emblem comes up push the toggle switch 5 times....you can now check the operation of the TPS and the other sensors....if you have the nismo upgrade you can hook up your laptop and see it all working....
check you fuel pressure at idle and on boost with the appropriate test gauge....from all the info here you should be able to directly pinpoint the problem
ascut and pasted from the other thread..........
link test terminal with the "-" terminal....turn the ignition on....then remove the the link....then your code will be displayed
if you got a power FC it wont work.....dude its really not that hard....if your still having dramas pm me and i will give you my number and talk you through it.....
Finally got new o2 sensors in...dear suckers..The others rattled and didn't register any volts.
Now it registers volts but only upto 1 v and the duty cycle still goes through the roof at high revs.
Don't the o2 sensors go to 5 volts?
  • 3 months later...
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
