huddy Posted July 17, 2005 Share Posted July 17, 2005 as it says what sort of diffs fit? cefiro with ABS? i'm guessing s13 ones fit, but also been told that r33 gts ones fit and s15 maybe? etc? would be good once its sorted to put this up in cefiroz.com thanks Link to comment https://www.sau.com.au/forums/topic/80810-what-diffs-suit-cefiro/ Share on other sites More sharing options...
pitchd Posted July 17, 2005 Share Posted July 17, 2005 rip ABS out!!!!! Link to comment https://www.sau.com.au/forums/topic/80810-what-diffs-suit-cefiro/#findComment-1468793 Share on other sites More sharing options...
RiverSide Posted July 17, 2005 Share Posted July 17, 2005 Remove the ABS for starters. You will find that it will depend on the type of diff your car came with from the factory makes a difference. If you are running the R200 already, then you can use diffs from SR20det S13/R32 skyline/R33/34 skyline (need to change the backing plate). Or of course cefiro or laurel diff. Link to comment https://www.sau.com.au/forums/topic/80810-what-diffs-suit-cefiro/#findComment-1469082 Share on other sites More sharing options...
pitchd Posted July 17, 2005 Share Posted July 17, 2005 what about s14/s14 nico? Link to comment https://www.sau.com.au/forums/topic/80810-what-diffs-suit-cefiro/#findComment-1469323 Share on other sites More sharing options...
huddy Posted July 18, 2005 Author Share Posted July 18, 2005 i'll try find out if i've got a r200 cheers. Link to comment https://www.sau.com.au/forums/topic/80810-what-diffs-suit-cefiro/#findComment-1470466 Share on other sites More sharing options...
replicate Posted July 18, 2005 Share Posted July 18, 2005 I think all turbos came with R200. Only the RB20e came with an open R180. But i stand to be corrected. Link to comment https://www.sau.com.au/forums/topic/80810-what-diffs-suit-cefiro/#findComment-1470729 Share on other sites More sharing options...
RiverSide Posted July 18, 2005 Share Posted July 18, 2005 I THINK S14/S14a should fit....but just like the R33/34 diffs you will need to change the rear cover. Best to double check on that though......as i have seen but not installed an S14 diff into cefiro/laurel Link to comment https://www.sau.com.au/forums/topic/80810-what-diffs-suit-cefiro/#findComment-1471318 Share on other sites More sharing options...
huddy Posted July 19, 2005 Author Share Posted July 19, 2005 i took pictures of it if that'll help? coz i'm still unsure? Link to comment https://www.sau.com.au/forums/topic/80810-what-diffs-suit-cefiro/#findComment-1473636 Share on other sites More sharing options...
meggala Posted July 22, 2005 Share Posted July 22, 2005 swapped the diff from my rb20e cef with a silvia diff r200 no problems Link to comment https://www.sau.com.au/forums/topic/80810-what-diffs-suit-cefiro/#findComment-1479643 Share on other sites More sharing options...
huddy Posted July 22, 2005 Author Share Posted July 22, 2005 ok i've found that i've got 5bolts to the driveshafts, so i'm assuming this is not r200, also it has ABS, so i've been told if i want to fit a r200 housing (with 5bolt to driveshafts) i'm going to need to swap the end of the tailshaft aswell??? Link to comment https://www.sau.com.au/forums/topic/80810-what-diffs-suit-cefiro/#findComment-1479717 Share on other sites More sharing options...
SideWaysChef Posted July 25, 2005 Share Posted July 25, 2005 Does anyone know how to identify a R200 I cant find anything in repair manuals, im guessing i have a R200 in my cefiro at present. I need to swap my diff to register it as the cops in WA aint exactly mech. LSD friendly I have checked out s13 diff(unsure if its turbo or non turbo as is out of car) but the drive shaft has different bolt up points Link to comment https://www.sau.com.au/forums/topic/80810-what-diffs-suit-cefiro/#findComment-1483178 Share on other sites More sharing options...
jaik Posted July 25, 2005 Share Posted July 25, 2005 LOL as if the police would know if you have a mechanical diff or not. My Cefiro was registered and engineer approved with a mechanical diff in it. Say "LSD" to a copper over here and they'll just say "open your glovebox, this is a random drug inspection". Peace out. JK Link to comment https://www.sau.com.au/forums/topic/80810-what-diffs-suit-cefiro/#findComment-1483192 Share on other sites More sharing options...
huddy Posted July 25, 2005 Author Share Posted July 25, 2005 ^^^ haha ... MEGGALA - was it a 5bolt? and did it have ABS? i guess i will have to try bolt up another one soon... if i can find one Link to comment https://www.sau.com.au/forums/topic/80810-what-diffs-suit-cefiro/#findComment-1483777 Share on other sites More sharing options...
replicate Posted July 26, 2005 Share Posted July 26, 2005 I've changed mine from R180 to R200. My R180 was 6 bolt, the R200 5. But this is not always the case!! My mates 180SX has an R200 with 6 bolt half shafts. Best way to identify would be to measure the diff from half shaft to half shaft. The R200 is wider. Hence why you need the different axels, its not just the bolt pattern. R200 axels are thicker and longer than R180. You don't need to do anything to the end of the tail shaft, mine bolted straight on. I still have my R180 sitting in the gararge. Too bad its absolutely worthless. I can measure it for you if you like. Link to comment https://www.sau.com.au/forums/topic/80810-what-diffs-suit-cefiro/#findComment-1484652 Share on other sites More sharing options...
huddy Posted July 26, 2005 Author Share Posted July 26, 2005 ok thanks, i'm thinking the best thing for me to do is buy a centre and housing... most likely r200 and simply see if it fits... if it doesnt, change the half shafts... thanks. Link to comment https://www.sau.com.au/forums/topic/80810-what-diffs-suit-cefiro/#findComment-1486121 Share on other sites More sharing options...
