Ok... After a year of owning the car with no problems whatsoever...i have finally came across one.
Problem that i'm having is -- the battery seems to be draining heaps quickly.
i have not driven my line for 5 days... so i assumed due to the cold weather..of course we get that awful cold start..i tried starting my car-- no luck.. till it just pretty much drained the battery. ( u get that "click click click " noise everytime u turn ignition on )
so i assumed battery was dead..i had it jump started and it went ok..started.. took for a 30min drive around town.. went to the supermarket for an hour.. when i got back.. the darn thing wont kick in.-- dead battery AGAIN.. so i jump started and worked OK. -- this i assumed the battery needs replacing as i had it ever since i bought it.--- so i got me a new one.. one click and the car started.. no problem. -- now went home and tried starting the car -- 4 tries and NO LUCK.. kept trying till i hear that " click click click " noise -- battery dead again.
i dont get it.. its fine when i jump start it.. starts pretty easy... but when i leave the car off for just 2 hours..it wont start.
I ruled out the alternator coz i had that problem with my previous car and the symptoms are not the same.. the car runs well..using aircon on / stereo and head lights.. nothing i know of that signs of alternator problem.
could it be the starter motor ? :confused:
Anyone who had the same problem and would be of help would be appreciated
thanks.
https://www.sau.com.au/forums/topic/80824-rb25det-power-drains-help/
If you've got a multimeter, put it in series with one of the battery leads and measure the current draw with key OFF. Should be close to 0. Anything more than 1/2 to 1.0 Amp will drain the battery pretty quick.
Is the battery voltage around 14v with the engine running?
If it jump starts OK, i'd doubt it will be the starter. Sound more like a lack of voltage problem.
hey does it just click or does it crank really slow??
plus double check the starter & battery terminals also you may have a volt drop on the switch wire to the starter
when you mean its flat are you sure its flat like are you head lights dim??
will your radio work??
if they do well could possible be starter related
just went and check the boot light and it was fine.. doesn't stay on.-- all terminals are fine.
and yes.. i can still play the radio / stereo and some lights.. but it just wont crank up.. and when it does.. it is slow.
could be a voltage drop.. dont think its the starter as it fire up fine when hooked up to another batery.
now.. how to fix this voltage drop..??
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25 The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
    • Nissan needs to forget about building SUVs in every size possible and bring back the damn Silvia/200sx duo to compete with the 86/brz. Maybe with the Honda type r motor pointing the right way
